Should I turn off the Traction Control if ...
Old 05-04-2007, 02:58 PM
NewMustang
NewMustang's Avatar
Default Should I turn off the Traction Control if ...
Should I turn off the Traction Control if I want to accelerate fomr 0 - 60 as fast as I can?
NewMustang is offline
Old 05-04-2007, 03:08 PM
GidyupGo
GidyupGo's Avatar
Default RE: Should I turn off the Traction Control if ...
No. If you have wheel spin, it won't be "as fast as you can."
GidyupGo is offline
Old 05-04-2007, 03:09 PM
acascianelli
acascianelli's Avatar
Yes.
acascianelli is offline
Old 05-04-2007, 03:11 PM
MrSandman
MrSandman's Avatar
Al little wheel spin is better than the ABS going of.. or the engine stalling.
ORIGINAL: GidyupGo
MrSandman is offline
Old 05-04-2007, 03:16 PM
Simon1
Simon1's Avatar
Youwould be better off, turningthe TCSoff and learning how to modulate the throttle. However, if you did a few test runs, and learned how to "launch" with the TCS on, you could learn a little more about the characteristics of your car. The TCS on these cars, is much better than than the previous model and will let the wheels spin substantially more than the 99-04 models.
Simon1 is offline
Old 05-04-2007, 03:20 PM
ORIGINAL: NewMustang
yes, turn it off. Learn to modulate your throttle. If you're in an auto doing a brake stand will help but not the best. Get a high stall converter and a brake line-lock setup.
You're not driving an M5 (2007+) where the traction control is smart enough to actually be better than driver control. It's been proven time and time again that with the M5, the european version is faster than theU.S. version due to launch control where the M5 does everything including traction control.
Old 05-04-2007, 04:16 PM
Stkjock
Retired Mod
Stkjock's Avatar
+1 to learn to balance the power and spin...
OFF FTW!!!
Stkjock is offline
Old 05-04-2007, 06:08 PM
2cokeman
2cokeman's Avatar
Doesn't the TCS kill power to the wheels??
2cokeman is offline
Old 05-04-2007, 06:13 PM
darkstang69
darkstang69's Avatar
i lost a raceagainst astock 07 mustang (mine is a 05stang) because i didnt turn off the the tcs
darkstang69 is offline
Old 05-04-2007, 06:14 PM
GidyupGo
GidyupGo's Avatar
ORIGINAL: 2cokeman
Yes, it can. I hear everyone here, but I was just thinking better that than go up in smoke. But, like most said, if you can feather the throttle, go for it. I launch with it on, and get a real nice responce. Maybe it's the limited slip.
GidyupGo is offline
Quick Reply: Should I turn off the Traction Control if ...
