how to remove rear bumper cover??
Old 05-04-2007, 08:56 PM
wwmost
wwmost's Avatar
Default how to remove rear bumper cover??
im looking to remove my rear bumper so i can get it painted and i can just bring in the bumper so i dont have to pay for them to take it off. anyone know how? cant be that hard
wwmost is offline
Old 05-04-2007, 09:32 PM
catch_15
catch_15's Avatar
Default RE: how to remove rear bumper cover??
there should be a bunch of push pins hoding in in on the bottom side and you'll have to remove the inner panels of your trunk to get to the other nuts that hold it on.
catch_15 is offline
Old 05-05-2007, 12:53 AM
wwmost
wwmost's Avatar
bump. anyone else?
wwmost is offline
Old 05-05-2007, 12:57 AM
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: wwmost
bump. anyone else?
Also there are some screws on the fender lip.
code3GT is offline
Old 05-05-2007, 01:00 AM
wwmost
wwmost's Avatar
ORIGINAL: code3GT
ORIGINAL: wwmost
bump. anyone else?
so thats it? im also gonna remove the side skirts as well... i think thats just screws on each end and pop out the plastic clips underneath right? and take off the door jam panel. im getting alot of new stuff on i can wait and get this stuff painted
wwmost is offline
Old 05-05-2007, 01:17 AM
Emanpimpster
Emanpimpster's Avatar
I just got done doing this. There are 5(i think) push pins conecting bumper to bumper reinforcement (3 in center 1 on each side. Then theres 2 screws in each fenderwell and the grommet think connecting the overflow tube from ur gas tank. Remove all those. Then you have to take out the interior panels in you trunk. The hooks for the cargo net unscrew and then you have to pop off the push pins from the plastic piece by the latch (4 or 5). Remove that panel, then the 2 side panels can be removed as well. There are 2 (1 on each side) metal clips that hold these to a piece of metal at the rear of your trunk on the sides. Pull these panels out and the trunk should be gutted except forthe trunk liner. If you want remove that too, 4 or 5 pushpins at rear bottom of trunk. There are ~7 nuts that you have to unscrew on the inside, just look for them and you will see. After everything is un bolted it should slide right off. Eric
Emanpimpster is offline
Old 05-05-2007, 04:01 PM
wwmost
wwmost's Avatar
damn that sounds like alot to do. how long did it take you?
wwmost is offline
Old 05-05-2007, 08:02 PM
Emanpimpster
it really isnt that bad. I took my time and labeled everything so it probably took an hour but the reinstall took 25-30 mins no big deal especially if it saves you $. And im only 17 so that shows you about how long ive been working on cars. Its easy.
svastano
25
07-16-2016 01:20 PM
JonnyBlazeGT
11-03-2015 01:10 AM
tj@steeda
Steeda Autosports
09-01-2015 08:16 PM
MustangHead91
08-23-2015 09:37 PM
inyadreems
08-21-2015 09:10 AM
Quick Reply: how to remove rear bumper cover??
