5.0 VALVE ADJUSTMENT
Old 05-05-2007, 04:53 PM
mustanggtlx
mustanggtlx's Avatar
Default 5.0 VALVE ADJUSTMENT
Newbie a little confused
Could someone please help?
I have a 90 mustang gt. I have read eveything I can get my hands on to find out to adjust my valves. Chilton say to bleed down the valve then adjust them. Ford tech say you don't need to bleed the valves.What the deal? Do I need to or not. What is the best way to adjust them.?Chilton has you do it in 3 steps. Some articles say do it1 cylinder at a time. I just put a crane rocker arm stud Converstion kit on. Dose this change the way you adjust them?
Thanks for any help
mustanggtlx is offline
Old 05-05-2007, 05:00 PM
thunderjet429
thunderjet429's Avatar
Default RE: 5.0 VALVE ADJUSTMENT
if you put a stud conversion on your car the factory positive stop procedure can not be used.
thunderjet429 is offline
Old 05-05-2007, 05:22 PM
67mustang302
67mustang302's Avatar
If you converted from pedestal to stud then yeah, you can't use the factory procedure. You'll have to go by what the rocker arm manufacturer says in their instructions
67mustang302 is offline
Old 05-05-2007, 11:34 PM
mustanggtlx
Thanks guys
But do i still need to bleed down the valves?Crane instruction says do 1 cylinder at a time, turn the adjusting nut 1/2 to 1 turn after you having taken out all the slack (zero lash).
Old 05-06-2007, 12:13 AM
CantStopTheFox...
CantStopTheFox...'s Avatar
From whatI read....you start at TDC (#1), and you torque bothvalves down to 18lbs......
Then you turn your crank a 1/4 turn.....to the next in the firing order......torque them both down to 18lbs.......
Continue through the firing order until you are done.
I am not sure if this is right, but that is what "they" say. I did that with my a car and it is running GREAT! If anyone else thinks that this is wrong, please let me know.....
CantStopTheFox... is offline
cr620
10-03-2022 10:18 PM
baddog671
07-26-2016 01:20 PM
Thunderball
15
11-22-2015 11:49 PM
Lethaldosage423
10-19-2015 12:12 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: 5.0 VALVE ADJUSTMENT
