Alternator Help! battery wont stay charged
Old 05-20-2007, 09:49 PM
86onboost
86onboost's Avatar
Default Alternator Help! battery wont stay charged
i had my mustang with a stock alternator, for a while, and the batter wouldnt stay charged. i would cut on the car, and disconnect the battery, and it would cut off, (bad altenator)
well i got myself a new 75amp alternator, and still the same thing, it wont keep the batter charged, we tried optima batterys and duralast, still the same.
Why wont my battery stay charged. Do i need a bigger amperage, or is there a special way to connect it.
BTW its the alternator with the plug, i tried one with a single wire, but still no luck.
86onboost is offline
Old 05-20-2007, 09:50 PM
AdderMk2
AdderMk2's Avatar
Default RE: Alternator Help! battery wont stay charged
disconnecting the battery to test the alternator... is probably what killed it
you backyard mechanic wannabe's make my job so easy
AdderMk2 is offline
Old 05-20-2007, 11:00 PM
86onboost
86onboost's Avatar
we also went to autzone, and the test was positive, but the car is supposed to stay on when the battery is disconnnected.
and the battery wont keep charge, we tried numerous of batteries.
we tried 2 plug alternators, and 1wire one, and still no luck.
do you think its the amp size , maybe 75 aint enough
Old 05-20-2007, 11:13 PM
foxstang89
foxstang89's Avatar
do you have underdrive pullies, a simple question but you never know
foxstang89 is offline
Old 05-20-2007, 11:17 PM
86onboost
86onboost's Avatar
yes , i am supercharged, i have the supercharge pulley, crank pulley, alternator pulley ( relocated to bottom) and water pump pulley, thats all i running
Old 05-20-2007, 11:29 PM
samseed101
samseed101's Avatar
When the car is running, what does your voltage look like?
And did you say you had underdrive pulleys with a supercharger? Your answer was kind of confusing.
samseed101 is offline
Old 05-20-2007, 11:41 PM
86onboost
86onboost's Avatar
what im sayin is that the only pulleys i have is supercharger, alternator, water pump, and crank
Old 05-21-2007, 12:07 AM
86onboost
86onboost's Avatar
also the amp i got was a 75 alt. from autzone.
maybe i connected something wrong, can anyone post on how to corretly install an alternator ( the one with the plug)
Old 05-21-2007, 12:25 AM
86onboost
86onboost's Avatar
anyone?
Old 05-21-2007, 12:29 AM
preciousroy
preciousroy's Avatar
75 is a bit low, try a 130 amp from an sn95
preciousroy is offline
Quick Reply: Alternator Help! battery wont stay charged
