painting valve covers?
Old 05-30-2007, 01:56 PM
ramprat
ramprat's Avatar
Default painting valve covers?
my dads valve covers are like, screwed they look horrible. - how hard is it to remove them and what exactly are they made of, are they plastic like the intake or aluminum or what? and has anyone else painted theirs with any success?
ramprat is offline
Old 05-30-2007, 02:09 PM
xcodegt
xcodegt's Avatar
Default RE: painting valve covers?
Is it a GT or a Cobra? GT valve covers are not too hard to remove, and if i am not mistaken...they are plastic. Cobra valve covers are aluminum I think. Someone painted theirs blue when doing an engine rebuild. They looked really good, but they were in a white car. I couldn't do the same to my car and make it look good under the hood
xcodegt is offline
Old 05-30-2007, 02:19 PM
ramprat
ramprat's Avatar
GT - what kind of gasket do they use ? is it a standard rubber gasket or RTV or ? and bah on plastic.. is everything on those motors plastic? lol
ramprat is offline
Old 05-30-2007, 02:31 PM
xcodegt
xcodegt's Avatar
Plastic is everywhere on these damn cars. My car had rubber gaskets on it. Not sure if they were stock or not because they had been off the car before I bought it.
xcodegt is offline
Old 05-30-2007, 04:25 PM
derf
derf's Avatar
The gaskets are rubber. Then ones that are OEM are black but Fel-pro makes blue ones. They are nice. Just loosen the bolts all the way around the valve covers but don't pull them out. The gasket keeps them in place. When you replaceit put thegasket in the valve cover first then push the bolts though to keep the gasket in place. Then set the valve covers on the heads and torque to spec. (not too tight)Use a small dab of RTV where the heads meet the timing chain cover.
derf is offline
Old 05-30-2007, 06:20 PM
oxfordgt
oxfordgt's Avatar
I painted mine blue with white stripes. Easy to do but taping off the lines will make you go cross eyed for awhile. I think they look good in my white car.
oxfordgt is offline
Old 05-31-2007, 02:07 AM
Chubstang
Chubstang's Avatar
ORIGINAL: oxfordgt
do you remember the kind of paint you used?
Chubstang is offline
Old 05-31-2007, 02:33 AM
oxfordgt
oxfordgt's Avatar
I used engine high temp paint.
oxfordgt is offline
Old 05-31-2007, 03:02 AM
breagles
breagles's Avatar
I did mine too in Ford blue . They may be made of fiberglass
breagles is offline
Old 05-31-2007, 10:42 PM
02WhiteGTVert
02WhiteGTVert's Avatar
ORIGINAL: oxfordgt
Damn,that sh*t looks very good. Got any pics of them on the motor?
02WhiteGTVert is offline
Quick Reply: painting valve covers?
