Old 10-08-2015, 01:30 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
starter or starter solenoid location
Old 06-06-2007, 10:18 PM
jusnkris
jusnkris's Avatar
Default starter or starter solenoid location
troubleshooting my mustang that wont start. its down to the starter or starter solenoid. where is the solenoid located and how hard is it to pull a starter on these?
jusnkris is offline
Old 06-06-2007, 10:41 PM
jusnkris
jusnkris's Avatar
Default RE: starter or starter solenoid location
anybody?
jusnkris is offline
Old 06-07-2007, 03:57 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
There's a starter relay located in the power distribution box by the driver's side strut tower that activates the solenoid, the solenoid ismounted onthe starter itself and used to kick the starter drive in as well.[/align][/align]R&R of the starter is the same as most other cars, disconnect the battery, undo the solenoid and power connections at the starter, pull 3 bolts fastening the starter to the block/bellhousing--go backwards to put it all back together...[/align]
cliffyk is offline
Old 06-07-2007, 04:44 AM
shakin_bakin
shakin_bakin's Avatar
guy up above is correcto.. just look under the passenger side of the car by the headers/manifolds there should be a lumpy thing there get it off has the solenoid attached to it should be 3 bolts and one of them is a reall bitch to get to i had to get mine from the front of the car... using extensions to get to it couldnt get **** to get it. you can see the top third bolt if you take off the tire and look at it through the fenderwell but it wont give you any more access to it just lets you see it so you know what you going for... hope this helps.
shakin_bakin is offline
Old 06-07-2007, 09:00 AM
lizzyfan
Underboss
lizzyfan's Avatar
And when you are done......leave top bolt out[:@]
lizzyfan is offline
Old 06-07-2007, 11:00 PM
jusnkris
jusnkris's Avatar
thanks
jusnkris is offline
Old 06-08-2007, 02:53 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
ORIGINAL: lizzyfan
Ha ha. That's what I always tell everyone.
96GT226410 is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
logan409
09-26-2015 07:43 PM
jc409
Convertible Tech
09-26-2015 08:28 AM
jaiidutch
09-14-2015 10:29 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
Quick Reply: starter or starter solenoid location
