IAC box removal??
Old 06-07-2007, 12:23 AM
ramprat
ramprat's Avatar
Default IAC box removal??
anyone removed the little box connected to the iac hose and just ran a plain old hose? theres nothing in it so i don't see why it'd hurt - but i wanna make sure.
ramprat is offline
Old 06-07-2007, 01:53 AM
BuzzCut
BuzzCut's Avatar
Default RE: IAC box removal??
That is a muffler. It will be very annoying without it. It doesn't affect performance so why ghetto it?
BuzzCut is offline
Old 06-07-2007, 02:02 AM
ramprat
ramprat's Avatar
the empty plastic box that connects from the intake plenum to the intake tube via plastic tube is a muffler? how is just putting a hose on it ghetto? :| you know what i'm talking about right?
ramprat is offline
Old 06-07-2007, 02:05 AM
BuzzCut
BuzzCut's Avatar
ORIGINAL: ramprat
Yes I do and it is a muffler. If it doesn't cost you power why remove it? When you just tear stuff off for NO reason that is ghetto maintenance. Do what you want but I can bet you won't like it that way for long.
BuzzCut is offline
Old 06-07-2007, 03:25 AM
ramprat
ramprat's Avatar
if it whines can't hear it over the s/c anyway i was wondering in the first place because on my wifes car it's just kinda dangling around with the hose and looks crappy - wasn't going to do it for power, its for asthetics - instead of having a silly box hanging around it'd be a hose.
looks silly for some reason to me
ramprat is offline
Old 06-07-2007, 03:48 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
At the risk of sounding overly simplistic, this would seem to me to be a quite reversible modification--so why not just take it out and see what happens?[/align][/align]It is a silencer. The airflow through the IAC (and the entire intake) is not a continuous stream but rather a series of pulses as each cylinder draws in air and fuel--the little airbox provides a reserve and dampening effect to the pulsed flow into the IAC to reduce any noise that might be generated. I suspect that it does also impact the idle control performance to some extent because of the dampening/reserve effect.[/align]
cliffyk is offline
Old 06-07-2007, 11:59 AM
AJ06GT
AJ06GT's Avatar
I always wondered what the hell that box was for.
AJ06GT is offline
Old 06-07-2007, 12:10 PM
BuzzCut
BuzzCut's Avatar
ORIGINAL: cliffyk
Doesn't affect anything and as far as dampning, IMO, Dampning is usually reserved for fluids. You could pull the hose off and affect the idle due to unmetered air entering the engine.
BuzzCut is offline
Old 06-07-2007, 12:15 PM
Brute03
Brute03's Avatar
so that box has a purpose after all
Brute03 is offline
Old 06-07-2007, 12:39 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Air is a fluid... [/align][/align]That is, it's motion and behaviour are governed by the principles of fluid dynamics...[/align]
cliffyk is offline
Quick Reply: IAC box removal??
