how much antifreeze
Old 06-19-2007, 04:06 PM
adumb
adumb's Avatar
Default how much antifreeze
trying to fill up my 91 with antifreeze and it seems i have been toping it off for the past couple days.. i checked my haynes manual but that book is probably the most useless service book i have ever bought. so does anybody have a number of how much antifreeze it should take. i have put in probably more then a gallon and a half already. i don't see any leaks but i am used to motorcycles that only takea quartso this seems like alot of antifreeze i am putting in
adumb is offline
Old 06-19-2007, 04:07 PM
HACKGT350
HACKGT350's Avatar
Default RE: how much antifreeze
untill its full haha. take the cap off and run it for a while let watch the coolant go down and then fill it as its running then fill your overflow
HACKGT350 is offline
Old 06-19-2007, 06:09 PM
Blckstng93
Blckstng93's Avatar
Should be closer to 3 1/2 gallons (14qts.) with a stock rad.
Like HACK said, just fill it with the engine running and add coolant until it covers the holes inside the rad. I add a lil to the overflow also up to the cold mark.
Blckstng93 is offline
Old 06-19-2007, 06:42 PM
7upedition
7upedition's Avatar
^+1... just keep filling, i buy 2 gallons when i flush n fill + h2o and use almost all of it.
7upedition is offline
Old 06-19-2007, 08:03 PM
adumb
adumb's Avatar
i wish i would have known this info before cause i really have no idea how much i have put in so far.
how long does the car need to run before the t-stat opens?
adumb is offline
Old 06-19-2007, 11:29 PM
Mustangkiler
Mustangkiler's Avatar
Until it hits 195 or whatever the thermostat temperature you have in it.
Mustangkiler is offline
Old 06-19-2007, 11:35 PM
Blckstng93
Blckstng93's Avatar
Let the engine cool. Remove the cap and check the level. Youll know if its full or not.
If the lil holes inside the rad are all covered, its full. Its easy.
stangin1996gt
09-21-2015 11:01 AM
96stang3.8
09-10-2015 06:42 AM
steelers743
08-31-2015 07:16 AM
LIVIN_LEGEND
11-17-2005 02:56 PM
Fishhawk
10-06-2004 12:33 PM
Quick Reply: how much antifreeze
