A/T problems (Flashing OD off light)
Old 06-20-2007, 03:32 PM
ShadowDrake
ShadowDrake's Avatar
Default A/T problems (Flashing OD off light)
Alright, O/D off light started flashing today, it refuses to shift...
I know the flashing O/D light is essentially the check engine light, for the transmission.
How do I go about figuring out what the problem is? Is there a code that can be scanned? What are the common causes of this?
It's a 99 expedition 4wd, but it's the same automatic tranny as in the stangs, figured someone here would know.
ShadowDrake is offline
Old 06-21-2007, 12:47 AM
ShadowDrake
Default RE: A/T problems (Flashing OD off light)
Bump. I know there's people out there who have had transmission problems.
Edit: Update. Has no reverse unless you rev it pretty high. Works fine when it's cold, once it warms up, it starts slipping and having problems. PLEASE HELP. I want to at least diagnose the problem before I take it some place or attempt to fix it myself. Are there diagnostic codes for the automatic transmissions? How do I access them?
Old 06-21-2007, 12:55 AM
cease4
cease4's Avatar
That happened to one of my friends explorer recently its a 95 but i doubt is the same trans the problem with his was the TPS Sensor if u can try and get it diagnosed even if the check engine is not on....
cease4 is offline
Old 06-21-2007, 12:59 AM
ShadowDrake
ORIGINAL: cease4
That's what I was wondering,if I take it to AutoZone and get the codes scanned, will anything come up? Thanks for the suggestion, too.
Old 06-21-2007, 01:27 AM
cease4
cease4's Avatar
Well i used to work there so it might sometimes the scanner actually picsup codes with out setting off the light but it doesnt hurt to try its free anyway
cease4 is offline
Old 06-21-2007, 02:52 PM
ShadowDrake
Ok, thanks again. The only issue is that it only takes a matter of minutes for it to slip out of drive (shift it into 2 to keep driving) and it'll go for a while, then 2nd will slip out, shift it to first, and before long first will start slipping also.
One final bump.
Old 06-21-2007, 03:30 PM
2k1gt
2k1gt's Avatar
Mine did it once. I have an aftermarket t-handle and I rewired the o/d button to a toggle on the dash. I guess the wires had come loose and it caused the problem. I just re-connected the toggle and reset the computer by unplugging the battery for a few minutes.
2k1gt is offline
Old 06-21-2007, 10:46 PM
96mod289
96mod289's Avatar
There are codes for the tranny-Get it scaned it could be one of a milllion things. The sooner the better
96mod289 is offline
Old 06-22-2007, 11:46 PM
2000NoviGT
2000NoviGT's Avatar
Mine does that once in a while but I have a B&N race tranny with a manual shift valve body so I dont think the O/D switch reads right.
2000NoviGT is offline
Old 06-23-2007, 05:18 AM
SikGT
SikGT's Avatar
ORIGINAL: ShadowDrake
I have a 99 Ford Explorer as my Daily Driver. I just got it back from Aamco today cause it was doing the same thing that you described. Mine wouldn't shift into the last gear "lock up" at highway speeds so the RPMs stayed high and I was losing gas mileage like crazy. I took it in and they did a computer diagnostic and told me all the electronics were fine. In the end after dropping the tranny it turned out to be the torque converter.
I got a new Torque Converter and a few smaller little things that were replaced for insurance and the total with parts and Labor came out to $2568.83
I was like DAYUM! But whatever. I'm sure the stealership isn't any better. I just told the guy "Whatever just get the damm thing back on the road." 4 days later, it runs like a charm.
Makes me wish I had more mechanical skills.
SikGT is offline
djbigskrilla
09-20-2022 01:04 AM
Soldier GT
12
08-20-2015 09:42 AM
jjwinel78
08-17-2015 03:34 PM
philster0306
08-10-2015 11:33 AM
Quick Reply: A/T problems (Flashing OD off light)
