where is the fuel inertia switch
Old 06-28-2007, 10:09 AM
piedraco
piedraco's Avatar
Default where is the fuel inertia switch
where is the fuel inertia switch on an 89 lx? I think that might be one of my problems. Will that affect the way the computer works? or does it just cut off the fuel and thats its only purpose?
piedraco is offline
Old 06-28-2007, 10:16 AM
Joel5.0
Joel5.0's Avatar
Default RE: where is the fuel inertia switch
Rear lights inside panel.....
Nope....it shoudn't cause any problems with the ECM....it simply cuts power off to the fuel pump when the switch trips by excessive vibration.
Joel5.0 is offline
Old 06-28-2007, 10:48 AM
piedraco
piedraco's Avatar
i will check that out when I get home. thanks
piedraco is offline
Old 06-28-2007, 11:07 AM
samseed101
samseed101's Avatar
Did the computer give you an error code when you scanned it? If so just clear the codes and test again.
samseed101 is offline
Old 06-28-2007, 11:11 AM
piedraco
piedraco's Avatar
no this weekend I will perform the koeo and koer tests, ive been so busy with work that I havent had a chance to do it.
piedraco is offline
4cylinderplus2
10-09-2020 07:45 PM
PaulH2
20
01-31-2016 09:48 AM
b8checker
10-08-2015 12:55 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: where is the fuel inertia switch
