PO340 code
Old 07-11-2007, 02:06 PM
Stang0005
Stang0005's Avatar
Default PO340 code
My check engine light came on and i ran a tuner and the code i got back was PO340. Can anyone tell me what the code is and how i could fix it? Thanks.
Stang0005 is offline
Old 07-11-2007, 02:31 PM
99shadowGT
99shadowGT's Avatar
Default RE: PO340 code
P0340 Camshaft Position Sensor circuit fault. google is your friend! someone else can chime in for a diagnostic
99shadowGT is offline
Old 07-11-2007, 02:35 PM
8banger
8banger's Avatar
CMP camshaft position sensor....Malfunction...
Note:most common cause is alternator Noise...Also = RFI-Radio interference and or Crankshaft position problems should be considered...
8banger is offline
Old 07-11-2007, 02:36 PM
jEEd
I ♥ Acer
jEEd's Avatar
ORIGINAL: 99shadowGT
+1 thats what i got when i searched it up. is your friend
jEEd is offline
Old 07-11-2007, 03:29 PM
Brute03
Brute03's Avatar
what kind of symptoms are you having? if a new cps doesn't fix it, i'm 95% sure a new/rebuilt alternator would...
Brute03 is offline
Old 07-11-2007, 04:07 PM
str8wick3d
str8wick3d's Avatar
https://mustangforums.com/m_3521141/tm.htm
Please read my post on what I hope will become a sticky. This should help you with this code.
str8wick3d is offline
Old 07-11-2007, 06:25 PM
8banger
8banger's Avatar
Read your post....But,,,,the alternator does not send ampreage or anything else to the Cam Sensor....Its due to ELECTRICAL INTERFERENCE....Radio interferance(RFI) can cause this also.The cam sensor is simply a magnetic pickup(same as the Crank sensor)...which produces a square wave pattern(on,duration or time,off) for cam signal (and crank)to the ecm....I've replaced more alternators than CMP sensors for these symtoms.Hence "usually the alternator"...just trying to clarify....
8banger is offline
Old 07-11-2007, 08:46 PM
Pest007
Pest007's Avatar
Yea, I had that problem with my Stang, turns out it was actually the Cam Position Sensor.... WOW
[sm=icon_beat.gif]
Pest007 is offline
Old 07-12-2007, 06:43 AM
8banger
8banger's Avatar
ORIGINAL: Pest007
[sm=icon_beat.gif]
Yes is usually cheaper to replace the CMP first for someone who doesnt know how to check it out(and that may very well fix it)...and if that doesnt fix it....next comes the alternator.....I've relaced a ****z load of cam sensors on the power strokes...but less than 1/2 dozen in x(15 years) on the fordcars..
8banger is offline
Old 07-12-2007, 09:01 AM
BBZracing
BBZracing's Avatar
Just fixed mine a couple weeks ago.
Replaced the cam shaft sensor and blewthe 2ndone out after driving a couple of miles. Had to do more investigating and found that my alternator was bad which can short out the cam shaft sensor since it is one of the most sensitive sensors in the car. After putting a brand new (not rebuilt) alternator and a 3rd cam shaft sensor problem is fixed.
Good luck
BBZracing is offline
Quick Reply: PO340 code
