How much is too much Compression for a SuperCharger
Old 07-12-2007, 01:13 PM
ajmodelski
ajmodelski's Avatar
Default How much is too much Compression for a SuperCharger
I am considering getting a centrifugal super charger, but I want to know. How much Compression is too much for a pump gas car. I am going to be doing a PI swap, and my compressions will be around 10.2:1. And I would like to do around 9 PSI. But I want to know if that is too much compression with the super charger.
ajmodelski is offline
Old 07-12-2007, 01:17 PM
lizzyfan
Underboss
lizzyfan's Avatar
Default RE: How much is too much Compression for a SuperCharger
With the right tune you'll be fine at 9 psi
Add an inter/aftercooler or meth injection https://mustangforums.com/m_3430620/tm.htm
I ran about 9psi for about a year with 10.5:1 compression with no probs
lizzyfan is offline
Old 07-12-2007, 01:32 PM
ajmodelski
ajmodelski's Avatar
What kind of power were you putting down at 10.5:1 and 9 PSI?
Old 07-12-2007, 02:52 PM
Rusmisel01GT
Rusmisel01GT's Avatar
If I remember correctly he was around 370ish rwhp... but im not sure how he built his motor... I know he had PI heads... thats all i know though...
Rusmisel01GT is offline
Old 07-12-2007, 04:21 PM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: ajmodelski
368 RWHP
lizzyfan is offline
Old 07-12-2007, 05:06 PM
1BadSonicBlue02GT
1BadSonicBlue02GT's Avatar
ORIGINAL: Rusmisel01GT
wow good call! 368hp. pretty close!
1BadSonicBlue02GT is offline
Old 07-12-2007, 05:10 PM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
you can change your piston head design to help lower compression... wont be cheap though and they need to be forged
2002GTAUTOVERT is offline
Old 07-12-2007, 05:36 PM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: 2002GTAUTOVERT
Another way is to get Cometic headgaskets that are thicker to lower compression
lizzyfan is offline
Old 07-12-2007, 06:17 PM
ajmodelski
ajmodelski's Avatar
Well, if it is an issue to have that much compression I would just rebuild the bottom end all together. But, I was reading an article that said because of the lag and the way the Cetrifugals work, higher compression is not as bad as it is for a roots style or turbo set up. So I figured Id ask, as I have heard 9 to 1 compression is pretty high for Forced Induction, but I was wondering if anyone had any idea if 10 to 1 is too much.
Old 07-12-2007, 07:23 PM
lizzyfan
Underboss
lizzyfan's Avatar
Centri's do not lag! 9:1 is good for a centri setup, 8.5:1 for twin screw/Roots
lizzyfan is offline
Quick Reply: How much is too much Compression for a SuperCharger
