Sponsored by: DashLynx
95 GT gauges stopped working - everything gone
Old 07-20-2007, 07:04 AM
mercury267
mercury267's Avatar
Default 95 GT gauges stopped working - everything gone
My dad has a 95 GT. He has factory gauges and they all stopped working, along with the odometer. I pulled the gauge pod and see that there is a small circuit board in a slot on the back, AND there is of course the green circuit pad on the back of the whole gauge face.
Is this a common problem? If so, is there a contol box that feeds this info to the gauges or does the car probably just need a new gauge cluster?
I think the temp, amp and oil pressure might still have the needles move to some kind of read out, but it is not accurate, meaning the needles move but not to what is a correct read out (i.e. showing any normal operation temp from a cold start, and shy high oil pressure, and so on). The speedo and tach also just sit at 0 no matter what... they don't move at all.
Any help is appreciated. I would like to buy the parts he needs to fix it and it would just be a stock replacement, no upgrades or conversions. If anyone had a lead on whatever the part would be to fix it, please steer me in the right direction.
Thanks
mercury267 is offline
Old 07-21-2007, 01:26 PM
turboblast
turboblast's Avatar
Default RE: 95 GT gauges stopped working - everything gone
you may have already done this but check for a blown fuse
turboblast is offline
Old 07-21-2007, 03:59 PM
94Blk5.0
94Blk5.0's Avatar
+ 1 Fuses, check the owners manuel to see which fuses controls the panel. Some higher voltage breakers are under the hood.
94Blk5.0 is offline
Old 07-17-2008, 11:47 PM
mercury267
mercury267's Avatar
None of these do the trick. The fuses are ok. None of the gauges work.
Old 07-18-2008, 02:57 PM
945LSTANG
945LSTANG's Avatar
disconnect the negative battery cable, disconnect both instrument cluster connectors, remove fuse 15 from instrument fuse panel. check for continuity at fuse 15.
tell me what you find after you try this.
945LSTANG is offline
djbigskrilla
09-20-2022 01:04 AM
67LimeCoupe
11-25-2015 08:55 PM
m4xx
09-01-2015 06:46 PM
jjwinel78
08-17-2015 03:34 PM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: 95 GT gauges stopped working - everything gone
