Drivers side window won't roll down
Old 08-01-2007, 05:27 PM
red96gtconvtbl
red96gtconvtbl's Avatar
Default Drivers side window won't roll down
I got in my car today and my driver's side door wouldn't roll down. It just hear a small click when I hit the button, but the window doesn't budge at all. The rest of my windows work perfectly, where's the problem exactly?
red96gtconvtbl is offline
Old 08-01-2007, 05:28 PM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
Default RE: Drivers side window won't roll down
motor.
2002GTAUTOVERT is offline
Old 08-01-2007, 07:13 PM
wgdt21
wgdt21's Avatar
wait a day. Mine has done that like 3 times. It will randomly not work, and there will be a click noise right under the driver side dash, and then the next day it will work fine.
wgdt21 is offline
Old 08-01-2007, 07:20 PM
yelw02GT
yelw02GT's Avatar
10 buck says its the motor, give a day, if nothing get a test light and follow the current, but i can already tell you what it is, i just had to do mine
yelw02GT is offline
Old 08-01-2007, 07:57 PM
adam_ferguson
adam_ferguson's Avatar
try taking off the door cover and giving the wondow motor a good smack with a extention or some thing. some times the gears need some lube and they get stuck. my window does it every now and then and all i have to do is give it some good old fashon fixing my smaking it around a bit. if it wont go down still then check the motor
adam_ferguson is offline
Old 08-01-2007, 09:55 PM
96GT226410
CSMG Moderator
96GT226410's Avatar
Easy way to check. Open your door. With the key on, hit the window switch for the window that's not working. If the interior light dims then you need to replace your window regulator. If not, it's usually a switch, but wiring is also a possibility. Window regulators are very common.
96GT226410 is offline
Old 08-01-2007, 10:43 PM
red96gtconvtbl
Alright thanks guys, good suggestions, I'll try them out tomorrow and see whats going on.
Old 08-01-2007, 11:35 PM
M1ke
M1ke's Avatar
same thing happened to me and the next day it was fine. now my left rear won't go down but there's no click.
any ideas?
M1ke is offline
Old 08-02-2007, 12:23 AM
96GT_PSL
96GT_PSL's Avatar
i actually just fixed my driver side window today. lol. pain in the *** to take the whole motor assembly out of the door. finally fixed it though and i now can roll my windows down again. no more ball sweating!
96GT_PSL is offline
Old 08-02-2007, 09:01 AM
mustangchris09
mustangchris09's Avatar
I've had good experience with this one, mine stopped working right before it was about to rain and i took the panel off and blah blah blah, but after i just couldnt figure it out because i could hear the motor trying to move it up but nothing. So i did the redneck thing and got a hammer hit one of the metal arms that moves the window up and down and then poof it worked.
mustangchris09 is offline
Quick Reply: Drivers side window won't roll down
