5.0 HO Engine
Old 08-02-2007, 12:12 AM
supraman408
supraman408's Avatar
Default 5.0 HO Engine
i found an engine that claims to be a 5.0 V8 HO 302 roller cam EFI engine complete with wiring harness and computer for $600. im not too familiar with these engines and wanted to know what are key characteristics i can look for when looking at the engine to really determine if it is a 5.0 V8 HO 302 roller cam EFI engine. The owner still has the engine in what he claims is an 88 mustang. any help is greatly appreciated. THANKS
supraman408 is offline
Old 08-02-2007, 12:14 AM
jakeachy
jakeachy's Avatar
Default RE: 5.0 HO Engine
5.0 L=302CID, so thats confirmed, as for roller cam i would make him take out the cam. if he doesnt or sways about the idea hes not a very honest seller. learned that the hard way..
jakeachy is offline
Old 08-02-2007, 12:24 AM
TAPOUT
TAPOUT's Avatar
Do you need the wire harness and computer??? I've seen 5.0 roller motors for ~$250
TAPOUT is offline
Old 08-02-2007, 02:07 PM
supraman408
how do you determine if its a HO other than the HO engraved? what is a roller cam? and what kinda horsepower does this produce?
Old 08-02-2007, 02:53 PM
Vader87
Vader87's Avatar
Honestly do you think a person is going to tear apart a running motor in a car it came stock with just to prove its a roller cam? Honesty has nothing to do with it. Now if he going to pull the motor out & apart & sell it piece by piece, that would make more sense.
ORIGINAL: jakeachy
Vader87 is offline
Old 08-02-2007, 02:56 PM
mattdel
mattdel's Avatar
all you need to do is verify the firing order on the distributor cap. if the motor runs, and the firing order on the cap matches the HO order, your all set.
mattdel is offline
Old 08-02-2007, 06:41 PM
tinman
tinman's Avatar
Sounds like the seller is really proud of that 5.0.
Should be no more $250 w/o 'puter and I don't think those 'puters are THAT much...........
tinman is offline
Old 08-02-2007, 07:41 PM
keek89gt
keek89gt's Avatar
The fact that it would say HO right on the plenum/ upper intake and if its out of an 88 odds are its HO
keek89gt is offline
Old 08-02-2007, 09:10 PM
creekrat
creekrat's Avatar
I can bolt an HO name plate on my lawnmower, that doesn't make it an HO. You can't tell if it is a roller cam just by looking at the cam itself (especially if you don't know how to identify an HO motor) Like Matt said the firing order is different on an HO motor, But that is not a guarentee either, the cam can be changed.You canpull the intake and see if it has roller lifters and the spider retainer, not a guarentee either, you can put these in a non HO motor. Only way to tell is to look at the casting #'s and identify it that way.
creekrat is offline
Nick Oliver
10-17-2018 04:22 AM
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
Pyrate Dave
09-10-2015 07:30 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: 5.0 HO Engine
