Rear end shake
Old 08-03-2007, 01:25 PM
koumiss45
koumiss45's Avatar
Default Rear end shake
Ok when I am drving down the highway at anything above 40 mph my car shakes when I let off the gas. It doesn't seem to matter what gear I am in, although it may do it more when I am at a lower rpm, it also does it in nuetral.... it feels like the back of the car is bouncing very rapidly and shaking.... it seems more up and down than side to side. it is a medium to large vibration...any guesses on what it can be....it doesnt do it when I am on the gas.
koumiss45 is offline
Old 08-03-2007, 01:41 PM
Pest007
Pest007's Avatar
Default RE: Rear end shake
I'd say tires are out of balance or bent rim
Pest007 is offline
Old 08-03-2007, 01:48 PM
jpmustanggt
jpmustanggt's Avatar
It's got to be something with the tires or suspension I think.
jpmustanggt is offline
Old 08-03-2007, 01:52 PM
koumiss45
koumiss45's Avatar
Wouldnt the tires be doing it at all times? And the suspension also? I was thinking it might have to do with when the drive line shifts position when i get off the throttle.
Old 08-03-2007, 02:22 PM
MrChubs1
MrChubs1's Avatar
I was going to say u-joints or trans mount, but it's weird that it does it in neutral too. Is it much worse if you decel from a higher RPM in a lower gear (hi-load decel)?
Pinion angle issue?
MrChubs1 is offline
Old 08-03-2007, 02:28 PM
Ryan86272
Ryan86272's Avatar
My tranny mount is bad..... Only when i give it gas or downshift... NOT in Neutra(no Torque) Once there is any torque u can hear it Knockin I dont think his problem is the Tranny Mount
Ryan86272 is offline
Old 08-03-2007, 04:39 PM
koumiss45
koumiss45's Avatar
I have the car lowered just a little, pro kit. Could a combination of a bad tranny mount plus this cause my issue? How can I tell if I have a bad mount, just get under it and look. Tranny mount is on top right?
Old 08-03-2007, 06:17 PM
ackuric
ackuric's Avatar
no the tranny mount is under neath the tranny in between the crossmember and the tranny
you would know if you had a bad tranny mount, your shifts would be horrid, and you'd feel the tranny bouncing around underneath you when cruising in o/d on a bumpy road. you wouldnt call it a rear end shake, the tranny is way closer to the front, and you feel it right where you sit.
my guess is rim/tire issue.
btw hijacking the thread, our stock mounts for the trannies SUCK, give way too much play. i wonder if code has upgraded his mounts to polyurethane or solid, hmmm.
ackuric is offline
Old 08-04-2007, 12:13 AM
koumiss45
koumiss45's Avatar
Again ... wouldn't that do it all the time? How about a U joint or a carrier bearing
Old 08-04-2007, 12:15 AM
koumiss45
koumiss45's Avatar
It doesnt seem to be rpm specific....seems to be speed of drive shaft specific...the faster that boy is turning the worse it is....and nuetral is maybe a little worse.
Quick Reply: Rear end shake
