Rear disc brakes from ranger
Old 08-05-2007, 10:35 PM
Toastintx
Toastintx's Avatar
Default Rear disc brakes from ranger
Hey guys I have a 65 with 10" drum rear brakes, 8 inch" rear end. I have access to aford 7.5" rear end with 10" disc brakes. My question is can I put these brakes on my pony?
Johnny
Toastintx is offline
Old 08-05-2007, 11:15 PM
restomod@16
restomod@16's Avatar
Default RE: Rear disc brakes from ranger
It all depends on what engine you got. It may not be worth it to get a smaller rear end, a smaller rear end cannot support the power of a V8. But if you have an I6, you should be ok. Also you would need to find an 8.8 or 9 in in order to handle the power and torque of a V8. In fact I would suggest going to the local Junk Yard and checking around for a ford 9". It would probly be cheaper too.
restomod@16 is offline
Old 08-06-2007, 12:15 AM
Colorado_Mustang
Colorado_Mustang's Avatar
I don't know the bolt patterns, but I believe the 7.5" has a different bolt pattern than the 8 inch. Master Power Brakes has some good kits. Not too many Ford cars came with discs that used the 8 inch or small-bearing 9 inch.
Colorado_Mustang is offline
Old 08-06-2007, 05:15 AM
Toastintx
Toastintx's Avatar
My bad on the misunderstanding I have a V8. I don't want to switch out the rear end I just want to use the brake set up from the 7.5. I was just wondering if I could remove the brakes from the 7.5 and put them on my 8". Oh by the way bolt pattern is the same 5- 4.5
Thanks guys
Johnny
Galactic
04-29-2019 02:56 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
musnicki
09-23-2015 07:11 AM
DoctorScary
09-09-2015 07:53 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Rear disc brakes from ranger
