1994 GT Rear Gears
Old 08-07-2007, 05:38 PM
94gtcobra
94gtcobra's Avatar
Default 1994 GT Rear Gears
What are the stock rear gears for a 1994 mustang gt, should i go with 3.73 or 4.10 , everyone tells me i should go with 4.10 for automatic but my rmp is going to be higher every time. I want to be able to rev up the 1st gear and be able to go at a fast speed and then shift. What would be the diffrence of each gear. The different characteritics of each one.
94gtcobra is offline
Old 08-07-2007, 07:09 PM
94TealGT
94TealGT's Avatar
Default RE: 1994 GT Rear Gears
stock is 2.73 or 3.08 depending. For a 5.0 auto 4.10 is the way to go for a kick in the pants unless you really drive alot of highway then go 3.73 i dont think 3.55 in an auto 1994 would feel like enough of a difference unless you have alot of power adders but by your previous post your just starting out.... GO 4.10's for the win
94TealGT is offline
Old 08-07-2007, 07:11 PM
samseed101
samseed101's Avatar
He could also have 3.27 gears stock. If your rear end is stock and you want to do it the easy way, just open up the driver's side door and look on the sticker. You should see an axle code there. It will say "AX" with a letter beside / under it. The axle code will tell you what the stock rear ratio is:
Next to / Under "AX" you will see one of the following characters... 8, E, M, Z. Here's what they mean:
8=2.73 conventional differential (not for the 5.0s unless someone swapped a 5.0 into the chassis)
E=3.27 Traction Lok limited slip differential
M=2.73 Traction Lok limited slip differential
Z=3.08 Traction Lok limited slip differential
samseed101 is offline
Old 08-07-2007, 07:14 PM
black89gt
black89gt's Avatar
you're wrong samseed... I have a 95 gt rear end in my car and the stock gears were 2:73 with Trac loc.
black89gt is offline
Old 08-07-2007, 07:18 PM
samseed101
samseed101's Avatar
ORIGINAL: black89gt
So explain to me how I am wrong.
Old 08-07-2007, 07:19 PM
samseed101
samseed101's Avatar
I know it's extremely rare, but occasionally, just occasionally... I have a slight clue what I am talking about.
Old 08-08-2007, 07:05 AM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: black89gt
lol wtf? second line from the bottom...
OnyxCobra is offline
Old 08-08-2007, 09:09 AM
samseed101
samseed101's Avatar
LoL. I must say, I've never had someone quote me, say that I am wrong, and then explain how I am "wrong" by repeating nearly exactly what I said.
It's along the lines of:
Me: 1+1 = 2
Them: You're wrong man, are you a ****ing idiot? When I added 1+1 together I got 2.
Old 08-08-2007, 09:12 AM
90_Mustang_GT
90_Mustang_GT's Avatar
Just check out the tag on the housing, states it right there. And i went with 3.73's and love em.
90_Mustang_GT is offline
Old 08-08-2007, 09:20 AM
ThrashN
ThrashN's Avatar
4.10's for sure
ThrashN is offline
Quick Reply: 1994 GT Rear Gears
