289 HP Increase after rebuild?
Old 08-19-2007, 12:38 AM
restomod87
restomod87's Avatar
Default 289 HP Increase after rebuild?
Could anyone tell me if there are any significant driving changes, such as power when it comes to an engine being rebuilt properly? My 289 that threw a rod comes back from the shop Monday so i can put it back in and was wondering if there will be any noticable HP increase, with the slightly bigger touque cam and re-honed cylinders and what-not...Just wondering, never done this before! thanks
P.S. Either way, it will def. be back and funnnnn to drive: 289, tri-y headers, stock 289 heads, 570 street avenger holley, glass packs, etc.
restomod87 is offline
Old 08-19-2007, 12:45 AM
67mustang302
67mustang302's Avatar
Default RE: 289 HP Increase after rebuild?
With stock heads it'd not gonna be night and day(unless the old engine was running on dead cylinders with crap compression). With a little bit of a cam you'll notice it'll run better, should be a bit more peppy and seem a little quicker, but it won't be anything huge. Now, if you have a decent cam in it, and put some good heads on, that'll be worth anywhere from 50-100hp. Just make sure you break your new cam in properly if it's flat tappet(if it is, then shame on you for not going with a roller cam [8D])
67mustang302 is offline
Old 08-19-2007, 11:22 AM
htwheelz67
htwheelz67's Avatar
until it loosens up it may feel slower if your 289 was running good before.
htwheelz67 is offline
Old 08-19-2007, 11:27 AM
my77stang
my77stang's Avatar
i think he'll notice a bump. usually replacing a 40 year old motor with a fresh one is worth something all by iteself. add in the slightly larger cam, the holley, better exhaust and he should be pretty damn happy once he breaks it in and can get on it
my77stang is offline
Old 08-19-2007, 02:59 PM
Colorado_Mustang
Colorado_Mustang's Avatar
A blue-printed/balanced engine will give quite a hp increase, actually. But, if it isn't specified, most shops won't do both to the degree really needed to make that difference.
Colorado_Mustang is offline
mungodrums
Suspension
05-16-2019 09:36 AM
Dathan
10-05-2015 05:52 AM
Drastang
09-30-2015 03:48 AM
TfcCDR
09-14-2015 12:08 PM
ryland
09-13-2015 12:35 PM
Quick Reply: 289 HP Increase after rebuild?
