Bent axle or caliper wont fully release
Old 08-21-2007, 01:18 PM
djb1187
djb1187's Avatar
Default Bent axle or caliper wont fully release
Can someone please explain to me what is causing this very annoying issue. I been having this problem where my car is making this loud brake squeal from the rear and i just changed the pads and rotors hoping that was the issue but it looks like it was not. Whenever i press on the brakes the noise goes away. I dont know how it can be a bent axle since the car never has a drag radial and i havent hit any curbs so someone please shed some light on this. It is really annoying me
djb1187 is offline
Old 08-21-2007, 01:25 PM
Default RE: Bent axle or caliper wont fully release
Chock the front wheels, release the e-brake, and jack up the rear of thecar. Find out which side is binding. You should be able to slip a piece of paper between the rotor and brake pad (both inner and outer pad). If you can't then you found the side that is binding. If it's not binding and you still hear the sound, then it could be your differential or wheel bearing making the squeal.
Old 08-21-2007, 01:35 PM
importkiller89
importkiller89's Avatar
sounds like a stuck caliper
importkiller89 is offline
Old 08-21-2007, 10:45 PM
djb1187
djb1187's Avatar
i called the guy who did the rear pads and rotors and he said the caliper looked fine and he put some anti-seize on it.
djb1187 is offline
Thunderball
15
11-22-2015 11:49 PM
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
lincolnshibuya
09-24-2015 10:46 PM
tj@steeda
Steeda Autosports
09-24-2015 09:18 PM
Quick Reply: Bent axle or caliper wont fully release
