Mustang II IFS
Old 08-22-2007, 03:13 PM
usmc69mustang
usmc69mustang's Avatar
Default Mustang II IFS
I am rebuilding my 69 fastback and I want to upgrade the front brakes and suspension so I thoought this would be a good all in one package. As I am also looking to put in a 5.0 EFI it would also allow more room in the engine bay. I was wondering if it was a good idea or not. I am new a this so I am looking for the advice from more seasoned entusiasts.
Thanks,
Wade
usmc69mustang is offline
Old 08-22-2007, 03:46 PM
Daze
Daze's Avatar
Default RE: Mustang II IFS
In My Humble Opinion or IMHO the only reason to install a mustang II system is to eliminate the shock towers in order to make room for a monster sized motor. The Mustang II set up is much more harsh than the original type. When it comes to brakes and handling I have found this formula leaves me very happy with the suspension. All these modifications replace the original equeptment with newer aftermarket replacement while maintaing the same basic configuration.
Performance alignment
UCA drop
Roller spring perches
Adjustable strut rods
1" sway bar
Stock springs with performance shocks like KBY
Granada Disc brakes
With these upgrades you still have the option of upgrading now or later to R&P steering if you so desire.
Daze is offline
Old 08-22-2007, 04:04 PM
tarafied1
tarafied1's Avatar
I agree with DazeCars, however in my friends case he basically had no front end so we went with the Mustang II instead of going back original (sorry guys). This car should have been crushed so you won't morn too much. It has been a big job but I think it will be sweet.
Craig
[IMG]local://upfiles/56180/2B24EA3B7B18469B9A3F3C9A9237E8B6.jpg[/IMG]
[IMG]local://upfiles/56180/2D52B9E581A34B06997F1AF5611D9BD7.jpg[/IMG]
[IMG]local://upfiles/56180/BF6A66228488422C9747EBD664E4CB9D.jpg[/IMG]
[IMG]local://upfiles/56180/BFB1A8194FDA4B6FBAAF0E6A56E238A1.jpg[/IMG]
tarafied1 is offline
Old 08-22-2007, 04:06 PM
tarafied1
tarafied1's Avatar
BTW he bought the 65 FB from the junkyard where I took the pic in my sig...
Old 08-22-2007, 07:04 PM
mikethebike
mikethebike's Avatar
ORIGINAL: tarafied1
Craig
NO FASTBACK 65/66 SHOULD EVER BE CRUSHED.
mikethebike is offline
Old 08-22-2007, 09:02 PM
Mr. Classic EFI
Mr. Classic EFI's Avatar
In the past couple of years, a lot of developments from Open track racing have rejuvenated the Classic Stang front suspension. It is much superior to the MII ront end and generally cheaper too. Previously the MII had the advantage of Discsand R&P to older stang dident have.
I agree with Dazecars, though would add, the Articulated strut rods can wait till the pocket book can fit them, and I would encourage the use of GT or Progressive springs, especially over 600-620lb springs. Though in the heavier 70's Stangs, they do have their placedo have their place.
Mr. Classic EFI is offline
Old 08-22-2007, 10:13 PM
67mustang302
67mustang302's Avatar
I'd do TCP's front coil over setup before I did a MII front end, it lets you take huge advantage of the leverage of that long lower control arm. Even just some good springs shocks with a negetive wedge spacer and lowering stock upper control arms will produce an EXCELLENT handling Mustang, and that's not even going to aftermarket control arms. MII has it's place like was said, when the shock towers have to be cut out in order to make room for a large engine.
67mustang302 is offline
Old 08-22-2007, 11:59 PM
andrewmp6
andrewmp6's Avatar
id only do the mustang 2 if it was a drag only car it kills the handling of the car.a 69 engine bay is huge you can shove a 460 in there easy. 67mustang302 i dont like tcp top mount looks kinda weak to me.i love global west coilovers they are worth the money. if i had to notch the shock towers id use http://www.rrs-online.com/ coilovers and there shock tower notching kit.but you dont have to touch the shock towers for a little 302. look at tarafields car hes got a 460 in a 68 with out touching the shock towers theres more room then you think.
andrewmp6 is offline
Old 08-23-2007, 12:39 AM
67mustang302
I don't like cutting on my car anywhere if I can avoid it. I figure I'll go with the wedge spacer drop kit, then maybe switch over to tubular control arms, but I doubt I'll spend the money to go to a coil over.
Old 08-23-2007, 11:31 AM
usmc69mustang
I am not really looking for performance handling since this car will be more of a cruiser. I was wondering about the everyday performance and feel of the MII system. I will look into the alternatives you guys brought up.
Quick Reply: Mustang II IFS
