How easy is it to Run a Turbo on a Carb'd 351w Fox?
Old 09-06-2007, 11:20 PM
Hurricanedt77
Hurricanedt77's Avatar
Default How easy is it to Run a Turbo on a Carb'd 351w Fox?
Hey what's up guys, I was thinking of some plans for the winter. And I was wondering how easy it would be to Turbocharge my 351W Fox.
By easy I mean in general, running the piping, headers and the custom air box. And even as far as jetting and tuning are concerned. And I'm not really farmiliar with the popular brands were that sold kits. I've heard Carbed Turbo setups react well, due to the Venturi in the carb. Beyond that, I've seen time and time again how the turbocharged cars make alot more power espeically in the top end range. But I'm thinking the torque alone of my motor should be enough to help the low end.
Any responses are aprecaited, I'm just looking to learn a little.
Thanks
Hurricanedt77 is offline
Old 09-06-2007, 11:45 PM
r.barn
r.barn's Avatar
Default RE: How easy is it to Run a Turbo on a Carb'd 351w Fox?
It's no sweat, just gotta get the right kind of blow thru carb.
Then just use a $160 "carb hat" to connect boost piping to carb
B&G Turbo makes a 351W turbo kit
or you can do a simple twin turbo kit using flipped BBK headers and Garrett T3/T4's and custom down tubes.
Space is a little bit of an issue, but can be worked around for sure.
I'm using realitively small twin turbos on my 351W and should have almost instant full boost before 2,000 rpm. (KB eat your heart out)
It will limit my top end power, but I dont care about 800+rwhp, 600 is plenty for me.
r.barn is offline
Old 09-07-2007, 01:17 AM
liketoskate1
liketoskate1's Avatar
did you ever finish your turbo set up?
i'm wanting to hear the results because i'm doing a 351w turbo build right now.
ORIGINAL: r.barn
liketoskate1 is offline
Old 09-07-2007, 01:35 AM
r.barn
r.barn's Avatar
It's being fab'd up now, along with custom EDIS-8 distributorless ignition system install
No more distributor ....... YAY!!!!!!!!
r.barn is offline
Old 09-07-2007, 09:09 AM
luckythirteen13
luckythirteen13's Avatar
very easy to turbo a windsor. check out turbomustangs.com, there is a whole section just for turbo carb setups
luckythirteen13 is offline
Old 09-07-2007, 09:12 AM
liketoskate1
hell yea thats so ****in sick! damn i remember when you were just doing h/c/i on you 302 lol are you keepin ur current motor combo the same and just adding the turbos?
ORIGINAL: r.barn
Old 09-09-2007, 02:28 AM
85GTsleeper
85GTsleeper's Avatar
r.barn what about some turbo set up kits for a 85gt w/ a 302. and also blow through or draw through would be best?
85GTsleeper is offline
Old 09-09-2007, 07:49 PM
tinman
tinman's Avatar
I would also like to know which would be best, the draw thru or the blow thru set-up.
Seems to me that carbs like cool air so my logic is telling me draw -thru.....
tinman is offline
Old 09-10-2007, 02:09 AM
85GTsleeper
serio g
bjdutch2005
03-24-2017 03:38 AM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
Luke9222
10-22-2015 11:55 PM
Pyrate Dave
09-10-2015 07:30 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: How easy is it to Run a Turbo on a Carb'd 351w Fox?
