5.0 torque specs heads intake upper lower
Old 02-12-2005, 02:12 PM
westrides
westrides's Avatar
Default 5.0 torque specs heads intake upper lower
im trying to put my engine back together i need the torque specs for the heads and intake upper and lower for my 88 5.0
thanks
westrides is offline
Old 02-12-2005, 02:22 PM
roundman
roundman's Avatar
Default RE: 5.0 torque specs heads intake upper lower
from my '88 shop manual the specs are: cylinder heads - torque in two steps, 1st step 55-65 ft-lbs, 2nd step 65-72 ft-lbs.
intake manifold to cylinder head bolts - 23-25 ft-lbs. with a note to re-torque with the engine hot
upper intake manifold to lower- 12-18 ft-lbs.
roundman is offline
Old 02-12-2005, 02:29 PM
westrides
westrides's Avatar
thanks roundman can i put the push rods in at the same time as the head go on witout loosing off the rockers
Old 02-12-2005, 02:34 PM
roundman
roundman's Avatar
NO, don't even try doing this!!! remove the rockers completely and install the heads and torque them down to specs using new head bolts as the factory bolts are "torque to yield" bolts which are only good for one use. then install the pushrods and the rockers and torque the rockers to spec and then install the lower intake.
roundman is offline
Old 02-12-2005, 02:41 PM
westrides
westrides's Avatar
i was told that 92 and up i cant use the original bolts but mine i could
Old 02-12-2005, 03:17 PM
roundman
roundman's Avatar
You might be right as I've looked back in the shop manual and it doesn't say anything about not re-using the head bolts for the '88 model year 5.0 but I know I've read that stuff about torque to yield bolts for so long I thought it applied to all 5.0's, not just the newer ones.
roundman is offline
Old 02-12-2005, 03:24 PM
westrides
westrides's Avatar
What do you set the rocker arms at when you put them back on?
Old 02-12-2005, 03:46 PM
roundman
roundman's Avatar
18-25 ft-lbs.
roundman is offline
Old 02-12-2005, 04:23 PM
westrides
westrides's Avatar
alright thanks
Old 02-12-2005, 05:31 PM
88PatrolCar
88PatrolCar's Avatar
Tourqe to yeild bolts were used on fords aluminum head engines. The cast iron head engines used re-usable headbolts.
88PatrolCar is offline
Quick Reply: 5.0 torque specs heads intake upper lower
