Coolant leaking?
Coolant leaking?
I'm having to fill my radiator up with coolant about every 5 to 10 days. I just get a low coolant light. So I top it off and I'm fine. but I have strange symptoms: Like sometimes the Temp gauge fluctuates and will go up to the over heat mark but then come back down.
Now could it be I'm leaking somewhere and I just cant see it? I checked my waterpump weep hole and dont think its leaking. I havent gotten underneath the stang yet with a flash light to really check it thoughrly. If its a heater core leak then where would i check for leakage, under the dash or what. Any pointers would be helpfull.
RE: Coolant leaking?
check for coolant in the oil or oil in the coolant overflow could have a bad head gasket is the car puffing out lots of white smoke out the exhaust ,start car put hand in exhaust then smell hand do you smell burning coolant if so you have a blown head gasket
If it was the heater core it would be leaking out of the firewall on the passenger side.Mine used to weap coolant from the seam on the side of my radiator.You should be able to find it pretty easy coolant doesn't evaperate.
ORIGINAL: bluepony1
i also have a coolant leak mine is coming from the heater core. turn your heat on after your engine warms up... if smoke comes out its prolly the heater core. I bought prestone radiator selant. i used one bottle and it really didnt do anything and then i bought a second bottle and voilah.. no more leaks. it runs perfect and no leaks... i love it.. yeah i do. try it
ORIGINAL: 91hatchgt
It is probably not a good sign if you don't have any coolant in your overflow!! Check your water pump too, how long has it been since you got a new one of those?
