The best HCI combo for under $1800 ?
Old 09-14-2007, 09:10 AM
  #41
AdderMk2
AdderMk2's Avatar
Default RE: The best HCI combo for under $1800 ?
ORIGINAL: tooslow5.0
ORIGINAL: AdderMk2
you can mill the heads, to a certain extent.. how much... i dont know
yes, 276hp... I had a full exhaust, CAI, UDP's, 15° timing, adjustable fuel pressure regulator, and I tuned it with a Tweecer R/T
thas pretty much the setup i have. do you know how much power you made before the tweecer? are those hard to program? also were you running a stock maf tb and injectors? btw thanks-
253rwhp, 294tq
and yes, stock maf, stock injectors.... etc
AdderMk2 is offline
Old 09-14-2007, 10:14 AM
  #42
WhiteWindsor
WhiteWindsor's Avatar
ORIGINAL: my77stang
my cheapness has led me to the following package in the "best bang for the buck" type of combo. sure, a better intake and some more expensive heads could be used, but we're not looking to break the bank.
patriot aluminum heads - 895.00
typhoon intake - 275.00
random roller cam - 200.00
cloyes dble roller chain - 40.00
fel-pro gasket set - 100.00
hardened pushrods - 40.00
crane energizer RR's - 200.00
total 1750.00
w00t w00t i did that on the first try too [8D]
*edited cause nothing lined up right when i posted [:@]
You decided to be the guinea pig? Great, cant wait for you to tell us how they perform.
WhiteWindsor is offline
Old 09-14-2007, 10:17 AM
  #43
my77stang
my77stang's Avatar
no no, im not buying anything LOL. that was my recommended list for that amount of money
my77stang is offline
Old 09-14-2007, 10:31 AM
  #44
WhiteWindsor
Damnit [:@].
Old 09-14-2007, 10:41 AM
  #45
my77stang
my77stang's Avatar
seriously though if i had the cash for better heads for my 289 i would try em, unless i had oodles of cash and then i'd be going CHI
Old 09-14-2007, 05:20 PM
  #46
tooslow5.0
tooslow5.0's Avatar
ORIGINAL: AdderMk2
ORIGINAL: AdderMk2
253rwhp, 294tq
wow, you added 23 rwhp with the tweeker. that souns like a worthwhile mod. is that something you need to do on the dyno, is is the butt dyno sufficient?[sm=bounceybounce.gif]
tooslow5.0 is offline
Old 09-15-2007, 06:57 AM
  #47
KovacMotorsports
KovacMotorsports's Avatar
wow, alot of good info on this thread- thanks guys! is it possible to mill the gt40 heads to regain some compression? or does it screw up the port and bolt alignment for the intake?
You can mill then .040" before you will start having manifold alignment issues.
KovacMotorsports is offline
Old 09-15-2007, 09:21 AM
  #48
AdderMk2
AdderMk2's Avatar
you should never attempt to tune your car unless you are in a controlled environment, with all the proper tools to do so... otherwise you may be walking home when you melt a piston or two
AdderMk2 is offline
Old 09-15-2007, 09:35 AM
  #49
tooslow5.0
tooslow5.0's Avatar
ORIGINAL: KovacMotorsports
THATS what I wanted to know---Thank you!----now, say I tok off .030 to be safe, what should that raise copression to? and is it goint o mess with my pushrod length?
the engine ive built have only been och engines, so milling only retards the timing, which is good for the powerband usually depending on setup.
Old 09-15-2007, 09:38 AM
  #50
tooslow5.0
tooslow5.0's Avatar
ORIGINAL: AdderMk2
so by the time you pay for the tweecer and the dyno time, its costing way more than just getting a dyno tune. or am i wrong?[&:]
Quick Reply: The best HCI combo for under $1800 ?
