98 3.8L horsepower?? h'much?
Old 02-20-2005, 03:28 AM
coty
coty's Avatar
Default 98 3.8L horsepower?? h'much?
what's the 98 3.8L spec'd out at as far as hp and torque ...
i checked ford.com, the 05 runs at approx 210hp ...
coty is offline
Old 02-20-2005, 04:43 AM
tightdogal
tightdogal's Avatar
Default RE: 98 3.8L horsepower?? h'much?
yes 210 hp is for the 2005 v6, the difference between a 1998 v6 and 2005 v6 is about 60 hp.
1998 v6's come with 150 stock.
tightdogal is offline
Old 02-20-2005, 09:31 PM
coty
coty's Avatar
ok then ... whats the technical differences in the motors ...
--- &/or---
what can i do to bring it up to speed. i just bot a 98 3.8L, and to the best of my knowledge [ i havent picked it up yet, bad weekend for financial matters ] it has a k&n induction system, unknown aftermarket dual pipes. i think it MAY have a chip installed [as if i even knew how to tell]. the guy who had it b4 seems to have known what he was doin with the car, it was well taken care of, cosmetically at least.
i'd like to hit 225hp before i start thinking about a supercharger, so i prolly have to look at engine kits as well. i know v6's can hit well over 265hp.
btw 172k miles, natural.
coty is offline
Old 02-20-2005, 09:33 PM
coty
coty's Avatar
just so y'all know, it has been 18 years since i have even thought about turning a wrench for performance reasons.
coty is offline
Old 02-20-2005, 11:25 PM
hawks05
hawks05's Avatar
could swap on the split port setup and get a cam
hawks05 is offline
Old 02-21-2005, 12:14 AM
cobra232
cobra232's Avatar
look up www.rpm-mustangs.com
they have heads,cams,pistons,rods,intakes and many other goodies for the 3.8.
for a great chip go to www.velocitymustangperformance.com justin at VMP is awsome at custom burning a chip for a specific setup
also check out the following sites:
www.moranav6racing.com
www.supersixmotorsports.com
you will find all you need to get more out of the stang
i would replace the stock gears right off the bat with 3.73's or 4.10's with a Ford T-lok or Auburn Differential and a richmond gear install kit
you can get a rear girdle from
http://www.taperformance.com/rearend.htm
part# TA 1805
this will help the 7.5 rear hold more power and the Auburn differential is more expensive but much stronger than the Ford unit
good luck
you can also ask the guy's at www.3.8mustang.com or www.v6power.net for guidance
cobra232 is offline
Old 02-21-2005, 12:37 AM
coty
coty's Avatar
wow ...
cobra man u filled my head with stuff enough for the week.
thanks guys ... i'm still listening and learning.
[ hawks05 said:
[ could swap on the split port setup and get a cam
uh ... whats that mean swap on the split port.
coty is offline
Old 02-21-2005, 01:12 AM
cobra232
cobra232's Avatar
splitport swap is a head and intake swap from a 99+ 3.8L stang
the splitports flow better thus adding power.
to do the swap you need a modified fuel rail made for the swap
ported single port (up to 1998) heads and intakes can flow enough for serious power and are close to ported splitports in flow.
both are good setups but i'd stick with the stock heads and intakes but ported from RPM mustangs
here is a pic of my 98 3.8's engine bay
you can see the ATI procharger mounted low in front of the engine
http://www.mustangmods.com/data/8456/pics.1_001.jpg
cobra232 is offline
Old 02-21-2005, 03:13 AM
BaltimoreStreetMods
BaltimoreStreetMods's Avatar
keep in mind that there are two ways of rating hp..... there is hp at the flywheel (HP)and also at the rear wheels (RWHP)
If memory serves, yours had 178 HP / 148 RWHP.
BaltimoreStreetMods is offline
Old 02-23-2005, 03:29 AM
cobra232
cobra232's Avatar
ORIGINAL: trebor871
nope they are 150hp at the crank and 215 torque
rwhp is about 120
cobra232 is offline
Quick Reply: 98 3.8L horsepower?? h'much?
