Headlight Adjustment
Old 10-03-2007, 12:02 PM
Novanutcase
Novanutcase's Avatar
Default Headlight Adjustment
Does anyone elses lights point down at the ground like mine do? I had to stick a piece of wood underneath the headlight so that it would point at least somewhat straight ahead so I can drive at night. Is there any way to adjust the angle of the beam? I've tried and tried to figure out how to do this but so far the only solution I have been able to come up with is the block of wood thing!
John
Novanutcase is offline
Old 10-03-2007, 01:15 PM
MustangMan00
MustangMan00's Avatar
Default RE: Headlight Adjustment
what yr?....if its a 99-04 theres a lil screw shoudl be a hex wrench u turn that and they can move up and down
MustangMan00 is offline
Old 10-03-2007, 03:12 PM
97modifiedmustangGT
97modifiedmustangGT's Avatar
Not hijacking but let's say it is a SN then how would you adjust, because mine are pointing too high and I always get flashed.
97modifiedmustangGT is offline
Old 10-03-2007, 04:15 PM
97targa
97targa's Avatar
ORIGINAL: 97modifiedmustangGT
ALL MUSTANGS have outer hex screws on the headlamps for adjustment. There are two screws for each! One corrects up/down and the other side/side Don't wedge a piece of wood or a pry bar in there to force your headlights!.. This is the dumbest thing I have ever heard!
97targa is offline
Old 10-03-2007, 05:17 PM
Novanutcase
ORIGINAL: 97targa
Hahaha! It's an '03 GT! So are they the hex screws with the philips head on the inside? Here are some photos of what I have! Can you point out the adjusters?
John
Old 10-03-2007, 05:49 PM
ShadowDrake
ShadowDrake's Avatar
Here you are. It's easiest to adjust it with the headlight in the car and on. Just turn it and see which way it goes and adjust it to where it should be. There's specifications in the manual but I don't remember them.
There is no horizontal adjustment... not that I know of anyway, the manual says only the vertical is adjustable.
ShadowDrake is offline
Old 10-03-2007, 05:50 PM
MustangMan00
right here is the only one i know of, i dont know where the side to side is if there is one
[IMG]local://upfiles/33307/D44E694B627D4443A6577129901F7871.jpg[/IMG]
Old 10-03-2007, 08:16 PM
Novanutcase
I tried that and it really didn't do anything. I'll try it again. Also, on the passenger side, the bulb cup that amplifies light to the rear diffuser is loose. Is there any way I can get into the actual light to push it back. It seems to have slid forward and is sort of dangling!
John
Old 10-03-2007, 08:22 PM
ShadowDrake
ORIGINAL: Novanutcase
John
The turn doesn't adjust a lot... at about 35-40 feet, a full turn moves the beam about 3" up/down.
There's no real way to get into the light to fix that... your best bet is to see what you can do about it from the bulb hole. You CAN pull the whole headlight apart but you'll never get it to seal back up properly and condensation will form in it all of the time.
Old 10-03-2007, 09:18 PM
Novanutcase
Got it to work! Thanks guys! Now I can see who I'm hitting at night! LOL!
John
cr620
10-03-2022 10:18 PM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
winner99
09-30-2015 07:04 PM
Drastang
09-29-2015 03:31 PM
Quick Reply: Headlight Adjustment
