REAR SIDE MARKER REMOVAL
Old 10-03-2007, 05:20 PM
03greyGT
03greyGT's Avatar
Default REAR SIDE MARKER REMOVAL
Hey guys, I was just wondering what the easiest way to remove the side markers on the 99-04s was. Do I need to remove the whole rear bumper cover? Thanks for the help...
03greyGT is offline
Old 10-03-2007, 06:26 PM
Emanpimpster
Emanpimpster's Avatar
Default RE: REAR SIDE MARKER REMOVAL
you have to remove bumper its screwed in from the back
Emanpimpster is offline
Old 10-03-2007, 07:29 PM
iowanine
iowanine's Avatar
You can go from the back bottom, there is a small jack that you can get to the 8mm nuts I believe. You just have to worry about snaking your hand up into there. If you can not, then you will have to remove the bumper.
iowanine is offline
Old 10-03-2007, 09:39 PM
ponyman1969
ponyman1969's Avatar
i just removed one of the 8 mm bolts, then broke off the the other. i take it that your installing clear ones? i put the new ones on with one bolt and some clear silicone. it works just fine, and they arent going any where.
ponyman1969 is offline
Old 10-04-2007, 01:20 PM
03greyGT
03greyGT's Avatar
Ok, thanks for the replies. Actually im takin the factory ones out, wetsanding the letters off of them, and Im gonna spray the nightshades and clear/wetsand them. Ill just save it for a winter project...
03greyGT is offline
Old 10-04-2007, 05:27 PM
kenv
kenv's Avatar
Wet sanding the DOT letters off?? They are really small, do you think anyone besides you will notice?
kenv is offline
Old 10-04-2007, 09:24 PM
racer02GTstang
racer02GTstang's Avatar
might as well wet sand them since hes painting it... it will be a cleaner paint job.
racer02GTstang is offline
drfister
05-03-2018 10:38 PM
spectreman
03-31-2016 09:26 PM
Scottyboy187
SVT Forums
11-20-2015 02:57 PM
Scottyboy187
11-05-2015 04:18 PM
kdryan
08-21-2015 04:01 PM
Quick Reply: REAR SIDE MARKER REMOVAL
