SVT Forums
Jack Points 03 Cobra
Old 10-11-2007, 12:53 PM
ModularMax
ModularMax's Avatar
Default Jack Points 03 Cobra
where do i place the jack to jack up thwe rear of the cari cant find a place i feel comforable putting preshgure on whwere am i supposed to jack the back tires up from
ModularMax is offline
Old 10-11-2007, 01:10 PM
AllVenom
AllVenom's Avatar
Default RE: Jack Points 03 Cobra
Get some full lengths welded in, they make excellent jacking points...
Otherwise...you can use the spot where the factory jack goes or use a piece of wood and hit the spot where the full lengths would get welded two.
AllVenom is offline
Old 10-11-2007, 02:08 PM
ModularMax
ModularMax's Avatar
full length sub-frame connectors?
Old 10-11-2007, 02:16 PM
97targa
97targa's Avatar
ORIGINAL: ModularMax
LOL..yeah right, like I can put a jack even under the frame without the connectors! Get a piece of 1" boxed steel and have it welded on the inside of the pinch weld. Works great for me...Thanks Kenny Brown Heck, I even have to lift my car a little to get under the pinch weld. 1.5" up front and .75" out back?????
There is a spot in the back on the gt's not sure bout cobras w/ irs. It's about 5 or so inches past the weld going into the car just infront of the tire. That's a solid firm lift point!
97targa is offline
Old 10-11-2007, 06:26 PM
AllVenom
AllVenom's Avatar
ORIGINAL: 97targa
Most 03/04 Cobra owners don't lower their car so the jacks they make for low clearances work fine. And yes, I meant full length sub frame connectors. I got the Maximum Motorsport ones. Very nice.
AllVenom is offline
lad30nyc
lad30nyc's Avatar
Go to Sears buy a craftsman floor jack and your done. True story; I was in hershey pa, and got a flat on my Navigator, had to lift that sucker with the jack from the factory, ohh and without any specific jack points. Had to lift her on the automated running boards and i lived to tell you this story and the truck is fine too, soothe cobra will be fine
lad30nyc is offline
Old 10-12-2007, 06:36 AM
AJ06GT
AJ06GT's Avatar
ORIGINAL: AllVenom
ORIGINAL: 97targa
Hehe, I think I need to see if I can find a low profile jack that will fit under my car.
AJ06GT is offline
jwog666
12-27-2021 08:09 PM
flash_xx
10-16-2015 07:23 AM
88 orangepeel notch
10-05-2015 09:03 AM
09-25-2015 09:06 AM
Quick Reply: Jack Points 03 Cobra
