How do I clear the check engine Light?
Old 10-21-2007, 05:41 PM
bbbngowc
bbbngowc's Avatar
Default How do I clear the check engine Light?
1991 Fox
Stock
Check engine light is on. I want to clear it. Is there a DIY method?
bbbngowc is offline
Old 10-21-2007, 05:47 PM
w8less
w8less's Avatar
Default RE: How do I clear the check engine Light?
unhook the battery for about 5 min and then re-hook it up
w8less is offline
Old 10-21-2007, 05:49 PM
bbbngowc
bbbngowc's Avatar
Been there, done that. Still on. What else can I try?
bbbngowc is offline
Old 10-21-2007, 05:52 PM
Joel5.0
Joel5.0's Avatar
DIY KOEO/KOER/Cylinder Balance Self-Test ... to ID what failure code(s) need to be fixed.
Joel5.0 is offline
Old 10-21-2007, 05:56 PM
w8less
w8less's Avatar
you said to clear not to fix. if you can identify the code you can fix the problem and not have to worry about the problem
w8less is offline
Old 10-21-2007, 06:08 PM
Woodard2589
Woodard2589's Avatar
what if the problem is having no smog or egr stuff on the car, cause thats the problem i have
Woodard2589 is offline
Old 10-21-2007, 06:17 PM
Joel5.0
Joel5.0's Avatar
ORIGINAL: Woodard2589
The only EGR codes that will cause the CEL to illuminate are 31 or 35, not having any of the smog solenoids (codes 8x) connected will not cause the CEL to turn on. The reason for the "EGR Simulators" is to force an EGR code 33 only, and not have the CEL turn on.
Joel5.0 is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: How do I clear the check engine Light?
