Why is my exhaust manifold glowing red
Old 10-23-2007, 08:28 PM
stang8689
stang8689's Avatar
Default Why is my exhaust manifold glowing red
I only drove the car for about 5 minutes, I did get on it a little but not over 5k. I smelt burning andI thought the breather popped off the valve cover. I pulled over and my exhaust manifold was fglowing red WTF. Anyone have an idea, it is a 2.3 turbo.
stang8689 is offline
Old 10-23-2007, 08:41 PM
92lxsleeper
92lxsleeper's Avatar
Default RE: Why is my exhaust manifold glowing red
umm... its running really lean??
92lxsleeper is offline
Old 10-23-2007, 08:44 PM
sleeper_inc
sleeper_inc's Avatar
A lot of people have glowing manifolds. It could be timing, lean, rich. If you can, pull codes or search on TF about the issue (I'm sure you don't have one though)
sleeper_inc is offline
Old 10-23-2007, 08:45 PM
mg man 75
mg man 75's Avatar
Does it still have a have the exhaust convertor in it. Drop exhaust off turbo. And see if does better. Pipe maybe stopped up. Old trick potatoe in exhaust pipe.
mg man 75 is offline
Old 10-23-2007, 09:15 PM
stang8689
stang8689's Avatar
It still ran as good as always, I'mstumped. I noticed valve cover gasket was leaking, could oil on the manifold make it glowing red? I don't think so
Old 10-23-2007, 09:36 PM
sleeper_inc
The oil would make it smoke but the glowing I'm sure is fine
Old 10-23-2007, 09:58 PM
TBird232ci
TBird232ci's Avatar
Driving it aggressivly will make it glow red. Mine has glown red more times than i can count. Had my downpipe glowing too.
Its a neat glow from under the car.
TBird232ci is offline
Old 10-23-2007, 10:19 PM
stang8689
stang8689's Avatar
If thats all it is i am happy as ****. It is the first time I've seen it, would a s.s header stop that?
Old 10-24-2007, 02:14 AM
hellion_79
hellion_79's Avatar
s.s header?
hellion_79 is offline
Old 10-24-2007, 06:14 AM
stang8689
stang8689's Avatar
stainless steel
Quick Reply: Why is my exhaust manifold glowing red
