Odometer not working?
Old 10-26-2007, 07:49 PM
qpHalcy0n
qpHalcy0n's Avatar
Default Odometer not working?
Just got my car back from the body shop and the odometer / trip meter isnt workin (ie: its not rolling). Its a 98 Mustang GT so its got the analog meter. I ripped the instrument cluster out and its all connected, everything's set on the tranny. How does the Odometer run? is it a seperate gear or is it run off the speedo or what?
qpHalcy0n is offline
Old 10-26-2007, 07:56 PM
98F150/GT
98F150/GT's Avatar
Default RE: Odometer not working?
do your dash lights and all work? I know that in my 95 when it burnt up the fuse that controlled the dash lights everything stopped working but the tach.
98F150/GT is offline
Old 10-26-2007, 07:58 PM
TX97GT
TX97GT's Avatar
There is a gear in there that runs it. My odometer and trip meter wasn't working and when I took it apart, the gear was just brittle and was stripped..
TX97GT is offline
Old 10-26-2007, 08:02 PM
GhostRider02GT
GhostRider02GT's Avatar
I worked on a Ford Ranger, swapped the cluster instead of the gear because it actually was cheaper, and it was fixed. If thats not the problem, then its the cable going to the cluster from the trans
GhostRider02GT is offline
Old 10-26-2007, 08:42 PM
97targa
97targa's Avatar
ORIGINAL: GhostRider02GT
Mine did the same thing. I swapped out my mileage with a cobra cluster and it was atually the electronics servo that initiates the gear to move! That was bad. It's mounted on the same panel(blue plastic)as the ododmeter and trip readings. It's a silver cylindrical thing.
97targa is offline
Old 10-26-2007, 09:44 PM
97targa
97targa's Avatar
pm'ed you
97targa is offline
Old 10-26-2007, 11:57 PM
penceman
penceman's Avatar
I have the same problem. So you guys are saying that if I swap the clusters, it'll be fixed?
penceman is offline
Old 10-27-2007, 12:29 AM
jst98gtmustang
jst98gtmustang's Avatar
Did the same thing on my Ranger swapped out the cluster,and it worked fine after that.
jst98gtmustang is offline
Old 10-27-2007, 01:13 AM
GhostRider02GT
well you could swap clusters and it should fix it, but on a stang, its cheaper the buy the little gear. On a ranger I picked up a cluster for 17 bux shipped because of low demand, and the gears were 25 + shipping, so I went with the cluster. On a stang, clusters are gonna be more expensive because of demand, the gear would more than likely be cheaper
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
mungodrums
10-07-2015 04:01 AM
Pyrate Dave
09-10-2015 07:30 PM
JoshyGT
09-07-2015 02:04 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Odometer not working?
