dash rattle
Old 11-04-2007, 01:37 AM
likemike99
likemike99's Avatar
Default dash rattle
anyone have a write up of how to fix the dash rattle? or at least one to remove the dash?
likemike99 is offline
Old 11-04-2007, 01:38 AM
laserred02
laserred02's Avatar
Default RE: dash rattle
where is your rattle at?
I have several: passenger and drivers side vents rattle. I pulled them out and I will be putting foam where they clip back on.
Also there is a rattle somewhere on the passenger side where the dash meets the A pillar, I think that I try to stuff foam or felt between them and see if that helps. I'm not sure if that helps you, or not.
laserred02 is offline
Old 11-04-2007, 01:39 AM
Ortoch
Ortoch's Avatar
i have a rattle behind my tachometer or just to the left of it somewhere cant figure out what it is might be the vent I will check taht tomorrow
Ortoch is offline
Old 11-04-2007, 07:27 AM
2cokeman
2cokeman's Avatar
These cars rattle in many areas of the dash and A pillars.......Have fun![:@]
2cokeman is offline
Old 11-04-2007, 12:51 PM
laserred02
laserred02's Avatar
anyone know how to remove the molding that runs from the base of the windshield and over the passenger window, same piece on the driver's side. I know there are rattles coming from that piece and I want to remove it, foam it, and have a quieter ride.
thanks!
Old 11-04-2007, 01:19 PM
Bmr4life
Bmr4life's Avatar
I plan on using some kind of fabric and something like a butter knife to jam it in all over the place. I hate how much these cars rattle.
Bmr4life is offline
Old 11-04-2007, 11:23 PM
likemike99
likemike99's Avatar
my rattle is just to the right of center right near the windshield. It is a problem with the vend foam that has lost adhesive. If you push down on the dash it stops. I don't want to stuff something in to fix it. I want to really fix it. I know the dash needs to come out but I am not sure of the whole process. So I need a schematic of the dash removal. anyone got one?
Old 11-05-2007, 04:51 AM
Stkjock
Retired Mod
Stkjock's Avatar
if ur under the 3/36 b-2-b take it to the dealer... I had a bad one.... they found two pcs rubbing and they used foam padding to eliminate it.
Stkjock is offline
Old 11-05-2007, 08:40 AM
06SilverStang
06SilverStang's Avatar
Try this, maybe it will help.
http://www.2005stang.com/viewtopic.php?t=1087
Glenn
06SilverStang is offline
Old 11-05-2007, 08:44 AM
blackout
blackout's Avatar
Problem: My dash rattles...
Solution: Turn the radio up, you're driving a Mustang.
You really should stay away from aftermarket exhaust... and you thought your dash rattled now!
Anyways if it really bothers you that much, go bother the dealer and let them waste their time on it.
-Jeff
blackout is offline
Quick Reply: dash rattle
