how exactly do you build a 302 into a 306?
Old 02-17-2008, 01:00 AM
93StreetFox
93StreetFox's Avatar
Default how exactly do you build a 302 into a 306?
i was just wonderin if there was any machine work involved, i've never messed with the bottom end at all
93StreetFox is offline
Old 02-17-2008, 01:08 AM
86 5.0L
86 5.0L's Avatar
Default RE: how exactly do you build a 302 into a 306?
its machine work, more specifically they bore out the cylinders 0.030in
86 5.0L is offline
Old 02-17-2008, 01:53 AM
93StreetFox
thats what i figured, you mind as well go 347
Old 02-17-2008, 01:54 AM
ih8chevy
ih8chevy's Avatar
well that means increasing the stroke.
ih8chevy is offline
Old 02-17-2008, 01:58 AM
a89fiveoh
a89fiveoh's Avatar
yeah i would go with the 30 over. you cant really go to big with the stock production blocks. the get weaker the more you go.
a89fiveoh is offline
Old 02-17-2008, 02:12 AM
jtmustang
jtmustang's Avatar
i just got my 306 runnin finally i have an idle video of it in general discussion
jtmustang is offline
Old 02-17-2008, 08:57 AM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Just want to point out that there is no power gains to be had by boring .030. It is done to true the cyclinder walls and make sure the rings have a good surface to seal agaist.
JD1969 is offline
Old 02-17-2008, 09:54 AM
302army187
302army187's Avatar
ORIGINAL: JD1969
what do you mean by the rings have a good surface to seal agaist?
so with the stock 302 isent good? and the 306 is more stable?
im unsure of your meaning in this.
302army187 is offline
Old 02-17-2008, 10:02 AM
JD1969
JD1969's Avatar
When an engine gets old the cyclinders wear and go out of round or havea taper worn into them. Boring the cyclinder will true it up and allow the rings to seal better. Boring is not generally done to increase displacment, you realisicly don't get much of an increase in engine size (.030 is only 4 cubinc inches on a 302) so you not getting much power from 4 cubes.
JD1969 is offline
Old 02-17-2008, 10:11 AM
OneFine89Mustang
OneFine89Mustang's Avatar
go for .40 over then to a 308
OneFine89Mustang is offline
Quick Reply: how exactly do you build a 302 into a 306?
