Tire Pressure 245/45/17
Old 02-24-2008, 09:17 AM
tmajikman
tmajikman's Avatar
Default Tire Pressure 245/45/17
What psi are you guys running in your tires for the 245/45/17s, I have heard to run 40 psi, but I have also ran 32 psi for almost any other vehicle I have had with stock wheels and tires. Thanks for any input, I am trying to figure out what would be the best for mileage and the best ride quality for my dd.
tmajikman is offline
Old 02-24-2008, 09:36 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default RE: Tire Pressure 245/45/17
40 is too much and will make the cars ride hard. I ran 32 in mine.
PRO50SC is offline
Old 02-24-2008, 10:00 AM
tmajikman
tmajikman's Avatar
Thanks Pro, Thats what I have in them now, I just want to double check what info I had known for the longest time.
Old 02-24-2008, 10:52 AM
Jfsram
Jfsram's Avatar
I have the same size tires on my 93. The sidewall reads 52 max and the door sticker reads 30.
I often change pressure, depending on my mood, driving style etc.
At the track, 40 psi. It's a stocker and I've ran 2.0 60's with that set up. Planned on dropping it if traction was a problem but never got that far into tuning.
On the streets, my town has alot of bumpy roads. I fear for the rim so I run 40. This keeps the sidewall stiff and will keep my rim from getting damaged by the potholes.
Often I get sick of the ride from 40 psi. "screw the rim" thoughts go through my head and I run 32 or 35 psi. It rides a little better but the thought of wrecking my rim will usually make me pump it higher.
Love to hear more thoughts on pressure for low profile non stock tires.
Jfsram is offline
Old 02-24-2008, 11:11 AM
stangman94
stangman94's Avatar
32 no higher
stangman94 is offline
Old 02-24-2008, 02:43 PM
OnyxCobra
OnyxCobra's Avatar
My tires are usually around 30psi
OnyxCobra is offline
Old 02-24-2008, 02:46 PM
Boss_Hotrod
Boss_Hotrod's Avatar
30/28 front/rear. Helps it hook some.
Boss_Hotrod is offline
Old 02-24-2008, 03:33 PM
golden_eye
golden_eye's Avatar
I have 255/45/17s but that's pretty close [8D]. My tires say 44max, but I run about 42 front and 38 rear for autocross. higher PSI will improve your gas mileage slightly but will make the ride harsher.
golden_eye is offline
Old 02-24-2008, 03:40 PM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: golden_eye
I have 255/45/17s but that's pretty close [8D]. My tires say 44max, but I run about 42 front and 38 rear for autocross. higher PSI whill improve your gas mileage slightly but will make the ride harsher.
Too much pressure can also wear the tire unevenly.
Old 02-24-2008, 04:32 PM
white93pony
white93pony's Avatar
ive always run what the manufacture recomends most say 44 max and i usually would put about 40. if you run too low tire pressure it will break down the side wall and result in premature tire failure.
white93pony is offline
Quick Reply: Tire Pressure 245/45/17
