What does it mean when ...
Old 03-21-2008, 12:37 PM
bbbngowc
bbbngowc's Avatar
Default What does it mean when ...
you connect the battery and the car is trying to start? The engine is rolling over and over.
bbbngowc is offline
Old 03-21-2008, 12:40 PM
AdderMk2
AdderMk2's Avatar
Default RE: What does it mean when ...
your starter solenoid is bad
AdderMk2 is offline
Old 03-21-2008, 12:43 PM
bbbngowc
bbbngowc's Avatar
shyt! This will be the third one.
bbbngowc is offline
Old 03-21-2008, 12:49 PM
AdderMk2
AdderMk2's Avatar
ORIGINAL: bbbngowc
disconnect the ignition switch wire, and see if it still cranks when you apply power. If so, the solenoid is dead. If it doesnt... you have an ignition switch issue
AdderMk2 is offline
Old 03-21-2008, 01:44 PM
bbbngowc
bbbngowc's Avatar
ORIGINAL: AdderMk2
ORIGINAL: bbbngowc
yup starter solenoid.
bbbngowc is offline
Old 03-21-2008, 07:05 PM
1989convertible
1989convertible's Avatar
your batt cable could also be crossing with your pos. starter cable.make sure your batt cable is not on the same side with your startercable on the solinoid. if you have gone through 3 already how long between replacing each of them?
1989convertible is offline
Old 03-21-2008, 07:11 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
by a good quality one
mjr46 is offline
Old 03-21-2008, 07:37 PM
Alero99
Alero99's Avatar
check your firing order if you happened to have touched the wires...
Alero99 is offline
Old 03-21-2008, 09:05 PM
cleanfitty
cleanfitty's Avatar
ORIGINAL: mjr46
buy a good quality one
I second that!
You can get junky ones that won't last and they'll be shorted (causing it to crank right out of the box)
Also, this may sound weird, but if your starter windings are starting to short and draw excessive current, it can arc the contacts when enguaged and cause them to 'weld' themselves closed, causing a continuous crank condition.
(This happened to my boss's explorer, he went through a couple of cheapies, a blue streak, and a motorcraft, and they would all stick randomly - even with the crank trigger disconnected - until he replaced the starter and the problem went away)
cleanfitty is offline
Old 03-25-2008, 07:20 PM
bbbngowc
bbbngowc's Avatar
I just bought a Motorcraft and put it in. All is well. What's a good quality one? I'll go get it still.
bbbngowc is offline
Quick Reply: What does it mean when ...
