Drivability problems with E303 cam?
Old 03-29-2008, 12:33 PM
91blackmustanggt
91blackmustanggt's Avatar
Default Drivability problems with E303 cam?
I'm hoping to get my car running better this year but it has an e303 cam which is known to be fussy. Anyonehaving any luck withthis cam?I have heard of people trying the idle adjustment plate,or drilling a 1/8" hole in the throttle body butterfly. First I am going to check the fuel pressure, throttle position sensor, vacuum leaks,etc. Here is a link I found interesting. http://www.fordmuscle.com/forums/lat...-e303-cam.html
91blackmustanggt is offline
Old 03-29-2008, 12:46 PM
kweb288
kweb288's Avatar
Default RE: Drivability problems with E303 cam?
....what? i have the e303 and havnt had a single problem, if it is giving you trouble just raise the idle speed a couple hundred rpm's or so until it idles right
kweb288 is offline
Old 03-29-2008, 01:03 PM
1990lxhatch
1990lxhatch's Avatar
I haveit as well and it's actually a rather mild stick. First cold start of the day should be a bit rough...I usually hold it at about 1200 for a few minutes and then it purrs all day with no problem at all. You likely have something else that's out of whack....MAF issue, Baro sensor issue, vac leak - something of that nature.
1990lxhatch is offline
Old 03-29-2008, 01:12 PM
Joel5.0
Joel5.0's Avatar
There are other components/mis-calibrations that could be causing the problem...... valve train, vacuum leaks, faulty sensors, fuel pressure, etc. Don't blame the cam, I have set E, B, X, Stg 1 setups w/out problems.
Joel5.0 is offline
Old 03-29-2008, 06:58 PM
1992lx5.0
1992lx5.0's Avatar
i have an f cam and no idle prob i run my idel at 900-950
1992lx5.0 is offline
Luke9222
10-22-2015 11:55 PM
ctgreddy
09-20-2015 08:35 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
ryland
09-13-2015 12:35 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Drivability problems with E303 cam?
