Fuel PSI GUAGE where does it go
Old 03-29-2008, 01:21 PM
Alero99
Alero99's Avatar
Default Fuel PSI GUAGE where does it go
i just rented a fuel Psi Gauge from my auto store and i followed theshiny fuel lines to behind the alternator and found a spot where it should fit, it has a black screw on plastic cap, and a schreder valve, i can push the side of the guage that goes into it, on to the piece and gas will come out but, the screw on theGaugepiece is far to large toscrew onto the piece on the rail... any other spots? or i gota get one with a smaller screw on peice
Alero99 is offline
Old 03-29-2008, 01:40 PM
1990lxhatch
1990lxhatch's Avatar
Default RE: Fuel PSI GUAGE where does it go
You just need the right size end on the fuel hose. That isn't a goofy size schraeder or anything... surprised that you would have gotten one that doesn't work?
1990lxhatch is offline
Old 03-29-2008, 03:17 PM
MustangMan628
MustangMan628's Avatar
^Not true. Ford has an uncommon size shrader valve on the old fuel rails. Most of the kits you rent at an auto store include the small Ford adapter, but if not you can buy one or make one like I did. It's definitely a smart investment if you plan on having a lot of Fords. I've loaned mine out 3 or 4 times at the track. I will check mine later on at my shop and tell you what size hoses and couplings and s_hit if I think about it. I also made my hose a little longer so it's easy to read from inside the car. I can put it right up to the windshield.
MustangMan628 is offline
Old 03-29-2008, 04:21 PM
Alero99
Alero99's Avatar
thanks man i appreciate it, i really wanna get my new FPR on and im afriad to do it with out using a gauge to set the psi
Alero99 is offline
Old 03-29-2008, 05:00 PM
bighungrymatt
bighungrymatt's Avatar
yeah you just need to buy an adapter, I have an extra laying around somewhere
bighungrymatt is offline
Old 03-29-2008, 06:39 PM
Alero99
Alero99's Avatar
anyone know the size of the valve so i can get an adapter piece?
Alero99 is offline
jwog666
12-27-2021 08:09 PM
TCStangerv6
10-11-2015 05:57 PM
Sixx
10-05-2015 07:36 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel PSI GUAGE where does it go
