T-5 Fluid Capacity
Old 04-04-2008, 07:21 PM
66 FastBach
66 FastBach's Avatar
Default T-5 Fluid Capacity
i just I.D. that i have a T-5 WC and at the Tremic Website it says to fill the fluid till it just starts to drip out the fill hole,but i remember seeing a post in here that said different than that. its probably best to follow the Tremic website Right??
66 FastBach is offline
Old 04-04-2008, 09:07 PM
Daze
Daze's Avatar
Default RE: T-5 Fluid Capacity
Where is the post that says not to???? That is why the fill plug is where it is so you know the perfect amount of fluid to put in it. here is a little trick, rather than filling the trans from the fill hole remove the plug, remove the shifter, and fill the trans from the shifter opening. When the trans gets full fluid will begin to drain out the fill plug.
Daze is offline
Old 04-04-2008, 10:02 PM
Gun Jam
Gun Jam's Avatar
I know the t5's use ATF but what kind of ATF? Deltron 3 or whatever or will any of them work?
Thanks
-Gun
Gun Jam is offline
Old 04-05-2008, 01:01 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
2-4. APPROVED LUBRICANT. Most T5
transmission models use DexronÃ’ II automatic
transmission fluid. Refer the vehicle owner’s manual
or service manual for lubricant specifications
taken from http://www.ttcautomotive.com/English...ice_Manual.pdf
rmodel65 is offline
Old 04-05-2008, 05:18 AM
kalli
kalli's Avatar
i just bought a T-5 from a fella who rebuilds and sells T-5 (a lot)
I asked him yesterday what fluid he would recommend and he says:
get dexron 3 or 4 for the fluid,4 qt's
..It holds just a little more than 3.
but yes, in all trannies with a fillerhole on the said it's usually: fill until its coming out that hole again.
And thx daze for the hint. I was always wondering if that would be possible (a LOT easier tan getting funnels and hoses etc)
kalli is offline
Old 04-05-2008, 12:17 PM
Daze
Daze's Avatar
ORIGINAL: Gun Jam
Thanks
-Gun
IMHO the best fluid to use is a full synthetic designed for manual transmissions that normaly use ATF. Simple reason is when the T5 was changed to ATF an off the shelf fluid was chosen. ATF works just fine but has things in it for ATs that your T5 does not need. A full synthetic designed to work in your trans is tailr made to have everything the T5 needs and nothing it doesn't. Also the fluid in a T5 needs to be changed every 20K miles. By running a full synthetic that change still needs to be done but is not as critical if don't do it as often as you should. I use this fluid
"Synchromax® is recommended for manual transmissions that specify an automatic transmission fluid or motor oil. It is also ideal for 4x4 transfer cases and / or 2-cycle and 4-cycle motorcycle gear boxes. Synchromax® is formulated with Royal Purple's synthetic, proprietary Synerlec® additive technology, which offers improved shift quality over a wide temperature range and reduced gear noise. Synchromax® is fully compatible with all types of friction materials and offers excellent corrosion and oxidation protection without affecting the soft metals commonly found in manual transmission synchronizers. Try Royal Purple® today and Feel the Difference!"
Daze is offline
Old 04-05-2008, 12:39 PM
Gun Jam
Gun Jam's Avatar
awesome thanks daze
Gun Jam is offline
Old 04-05-2008, 04:11 PM
kalli
kalli's Avatar
can't get royal purple over here. so what is suggested ? is there any spec that I can go by?
kalli is offline
Old 04-06-2008, 09:25 PM
66 FastBach
thanx for the info. during the tranny service i took the driveline off to get it balanced and the next day i get a call and find out its bent!!! that explains the little vibration i was feeling and the reason i was doing all this.
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
wraith777
09-28-2015 10:49 AM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
09-25-2015 06:42 PM
Quick Reply: T-5 Fluid Capacity
