loud squealing coming from flywheel/bellhousing area
Old 04-07-2008, 01:09 AM
ddg1025
ddg1025's Avatar
Default loud squealing coming from flywheel/bellhousing area
i have a 1990 lx 5.0 5 speed that i just put a complete 1998 5.0 explorer engine into which i had to install a pilot bearing into as it didnt have one (being an automatic). i get this loud squealing sound when it warms up and when i shut it off sometimesit makes this really loud strange noise after the engine is off. i have had the transmission out twice and have replaced the pilot bearing and put the engine block plate onwhich i forgot to put on when i built it. any ideas on what this squealing noise might be and what to do to fix please tell me as this is very annoying to drive around with. thanks, dylan
[IMG]local://upfiles/84667/1B5A9C2B92834F019A7D71F0530878CC.jpg[/IMG]
ddg1025 is offline
Old 04-07-2008, 06:49 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: loud squealing coming from flywheel/bellhousing area
ddi you try replacing the throw out bearing yet for the clutch??
mjr46 is offline
Old 04-07-2008, 10:34 AM
HACKGT350
HACKGT350's Avatar
thats the same thingi was thinking. throw out could be bad and is pretty common
HACKGT350 is offline
Old 04-07-2008, 04:59 PM
ddg1025
ddg1025's Avatar
i inspected it and it seams alright it doesnt sound like it coming from that area
ddg1025 is offline
Old 04-07-2008, 05:49 PM
mjr46
mjr46's Avatar
ORIGINAL: ddg1025
it's possible the spacer plate/inspection plate could be hitting the balance weight on the flywheel to...upon removel if that's the case there will be score/scrape marks
mjr46 is offline
Old 04-07-2008, 06:13 PM
brentloftis
brentloftis's Avatar
My first guess is throw out bearing, second guess is wrong pilot bearing for the shaft or bent shaft, third and final.... clutch installed backward....... I would replace both pilot and throwout bearing and inspect the shaft and make sure the clutch/ flywheelis good and not any hot spots or gouges.
brentloftis is offline
Tivo304
08-28-2023 12:19 PM
Nick Oliver
10-17-2018 04:22 AM
Insidian
Carolina Regional Chapter
09-08-2015 05:33 AM
Mobiusone stang
09-07-2015 08:46 PM
TimeLord101
09-04-2015 09:27 AM
Quick Reply: loud squealing coming from flywheel/bellhousing area
