How To: Repin your harness
Old 04-17-2008, 07:30 PM
sleeper_inc
sleeper_inc's Avatar
Default How To: Repin your harness
How to re-pin a harness. I'm using a 1989 harness from a 2.3 manual car. It should be the same for a 1987-1990 mustan with either a auto or manual transmission (since its only the computer to engine bay harness)
This is a wiring harness out of a 1987-1990 mustang 2.3. Its the computer to engine bay harness.
The protective black case on top helps stop the pins from backing out and also protechs them from rubbing on metal and shorting out.
Here I took the case off to get at the pins using a small screw driver.
Another way of keeping the pins in is this red casing. Remove it using a small flat headed screw driver with a back and forth motion (like in the next picture)
The inner casing has been removed, and now the pins are ready to be removed.
**Make sure to number what side has what number of pin to make it easier to see where the pins go (trust me, this helps alot because then you don't have to move the harness back and forth between yourself and the computer).
I found using a small zip tie works well for taking the pin out without damaging it in any way shape or form.
List what color wire is going to do what (stops you from getting confused and wiring it incorrecty)(Quilty of doing that)
This is how I joined the two wires without cutting a connection. Stip the insolation off the wire being connected (about a 1/4") then strip and cut about the same from the wiring being connected to. Then solder the joints together, and then tape to keep them from touching, causing them to short out.
Since my wiring harness was out, I connected them higher up to make it cleaner and look stock(ish).
Had to drill a hole through the gromit because of the gauge of wiring I used, but its also a blessing because it made it easier to move the wiring closer to the wall for a mounting point.
I also deleted my A/C condenser and clutch lines since I longer want A/C
Wiring all together and ready to be installed
sleeper_inc is offline
Old 04-17-2008, 08:23 PM
Stang2.3
Stang2.3's Avatar
Default RE: How To: Repin your harness
Awesome bro.... Now about how long do these wire need to be?
Stang2.3 is offline
Old 04-17-2008, 08:57 PM
sleeper_inc
I made mine about 7 feet, and I cut the extra off
Old 04-17-2008, 08:59 PM
Stang2.3
Stang2.3's Avatar
Sweet.... so now i need wire.......
Stang2.3 is offline
Old 04-23-2008, 05:52 PM
Stang2.3
Stang2.3's Avatar
bump...... workin on wiring
Stang2.3 is offline
Old 04-23-2008, 06:03 PM
Stang2.3
Stang2.3's Avatar
havin problems takin the pins out.... how you get them out??
Stang2.3 is offline
Old 04-23-2008, 08:06 PM
sleeper_inc
I used a zip tie, shoved the little pointed end into the clip holding the pin inplace.
Old 04-23-2008, 08:11 PM
Stang2.3
Stang2.3's Avatar
i got em thankz bro!
Stang2.3 is offline
Old 04-23-2008, 08:25 PM
sleeper_inc
No problem, its alot easier to do it this way that with something metal. Plastic bends, metal dosen't[&:]
Old 04-23-2008, 08:32 PM
Stang2.3
Stang2.3's Avatar
No Problem.... so all i need to wire is four wires???
Stang2.3 is offline
Quick Reply: How To: Repin your harness
