how to install a distributor help plz
Old 04-18-2008, 05:15 PM
88 black horse
88 black horse's Avatar
Default how to install a distributor help plz
im new with this car stuff but i was wondering how to install a distributor on a 88 5.0 gt [:@]thanks
88 black horse is offline
Old 04-18-2008, 05:38 PM
cheetha94607
cheetha94607's Avatar
Default RE: how to install a distributor help plz
turn engine to top dead center (look at the center lower pully for (0) and place in the center of the pointer) install distributor with the distributor pointer pointing to the #1 spark plug wire(distrubutor must be fully seated with distributor pointer pointing to the #1 spark plug wire).
place locking bracket for the distributor into place and snug bolt. start vechicle and adjust timming(might need to adjust the distributor to get started).
cheetha94607 is offline
Old 04-18-2008, 07:27 PM
94StinkinLincoln
94StinkinLincoln's Avatar
TDC (top dead center) on the COMPRESSION stroke.
put the dizzy in and rotate the base until it is on the #1 spot on the cap. then pull the spout connector, tighten down the dizzy enough that it wont spin freely but u can make it twist, then fire it up, aim timing light at pointer, rotate dizzy until the pointer is at 10 (clockwise=advance) then kill it, put spout in, tighten down dizzy and you are good to go.
94StinkinLincoln is offline
Old 04-18-2008, 08:35 PM
WhiteWindsor
WhiteWindsor's Avatar
Here is a tech article for it. I personally use a long screwdriver and put it in plug #1. I turn engine by hand till the piston is at it's highest point and then reverse rotation just a hair untill piston starts moving back down then i go the other way till it reaches it's highest again. Like lincoln said you must be on the COMPRESSION stroke which is explained in the tech article.
WhiteWindsor is offline
Old 04-18-2008, 09:37 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
there is a tech article for this procedure by addermk2 in the stickys
mjr46 is offline
mtgldr
02-03-2024 09:00 PM
Omgitsa88Stang
10-05-2015 07:33 AM
StalkerGT
09-25-2015 02:41 PM
Quick Reply: how to install a distributor help plz
