Biggest cc engine i can fit in my mustang
Old 04-21-2008, 04:08 PM
Drew4537
Drew4537's Avatar
Default Biggest cc engine i can fit in my mustang
I have a 2000 v6 mustang and i was wondering what would be the biggest cc engine i could possibly fit in it.
Drew4537 is offline
Old 04-21-2008, 05:28 PM
ESG-642T
Buyer Beware
ESG-642T's Avatar
Default RE: Biggest cc engine i can fit in my mustang
How much money you got to spend?
ESG-642T is offline
Old 04-21-2008, 06:17 PM
l_shizzle_l
l_shizzle_l's Avatar
why?
l_shizzle_l is offline
Old 04-22-2008, 01:38 PM
Tee_Whet
Tee_Whet's Avatar
You just want to drop a motor in? Then you can drop a 351 stroke them to a lot bigger.
If the sky is the limit and you have the money, you can put anything in one!
Tee_Whet is offline
Old 04-22-2008, 01:39 PM
Tee_Whet
Tee_Whet's Avatar
http://www.youtube.com/watch?v=W_6OG4xQEjQ
Tee_Whet is offline
Old 04-22-2008, 02:40 PM
jthorn9
The Godfather
jthorn9's Avatar
Well if you're rich and have money to blow the largest engine, to my knowlege, that can reasonably fit into an Sn-95 Mustang is a GM LS7 motor. You'll need to do a nice deal of modifications, but it will fit, and you'll be bad as hell afterwards.
jthorn9 is offline
Old 04-22-2008, 03:09 PM
The Yellow Pinto
Guest
Posts: n/a
i think vcs hit the nail on the head when he asked how much he wanted to spend. if you want the LARGEST engine, ive seen people fab vette engines into rx-7s, 5.0s into focuses, etc. however, it will not necessarily be the best bang for the buck. for the amount of fabbing to drop the "largest engine possible" into a v6 stang, itd probably be cheaper to just sell the car and buy the one the big motor originally came in, with no downtime.
Old 04-22-2008, 04:22 PM
jmonty
jmonty's Avatar
ORIGINAL: Tee_Whet
i wonder what it would cost to get a nice 351 and tranny installed--i assume a tranny would be needed..
jmonty is offline
Old 04-23-2008, 01:34 AM
NeoTokyo
NeoTokyo's Avatar
well unless you want to have it carbed there is going to be a huge deal of wiring going into it.
Probably the easiest wiring would be a FAST managment system.
The 5.4L is a good base to work with and mixed with a 3.75" bore with its stock 4.165" stroke you get a nice 368 cubes (6.0 - 6028cc's)
Also if you waitRoush is working on a new 7.0L mod motor to add to their line up. On E85 alone it produced over 700rwhp. It was in one of the MM&FF magazines.
http://forums.musclemustangfastfords...-v8/index.html
I have to say though, its pretty sad when MM&FF stick to their guns on a sinking ship, any idiot can look at those pictures and know its a mod motor. They just tried to save face is all. The last post killed itfor good.
NeoTokyo is offline
Old 04-23-2008, 08:20 AM
Tee_Whet
Tee_Whet's Avatar
It depends. You may be able to find an engine you can rebuild, which is what I would do. Find one that is blown up and rebuild it. Yeah, def. a new transmission at somepoint. Once again, hit up a junkyard to find one. I know guys that have used old 5.0 John Deere motors. You could pull a 5.4 out of a Navigator w/ the wiring harness. But a 351 you would probably want to Carb it, which I rather have a Carb over EFI because of simplicity.
As far as 5.0s in Focuss... try twin turbo 5.4. There is one running around central ohio.
AND ISNT IT A SIN TO PUT A CHEVY BLOCK INTO A MUSTANG? AND YOU CALL YOURSELF A MUSTANG PERSON? [sm=icon_beat.gif]
Tee_Whet is offline
Quick Reply: Biggest cc engine i can fit in my mustang
