A How To: changing manual transmission fluid
Old 01-30-2014, 12:15 PM
  #131
GCCBrian
GCCBrian's Avatar
I'm running into some trouble here and I could use some help. I've tried taking the filling plug off first but for some damn reason it's just not coming off! The car is 8 years old and has been garaged its whole life, it only has 38,000 miles. This i the first time it's ever going to get changed. I've even tried using a breaker bar and it's just not coming off. Can anyone suggest an alternative way to getting this thing off?
The transmission is the TR3650 off the 2006 Mustang GT
- Good thing I went for the fill plug first because if i drained it and couldn't get the fill plug off I would've been screwed
GCCBrian is offline
Old 01-30-2014, 05:54 PM
  #132
AutoXRacer
AutoXRacer's Avatar
The plugs have treadlock on them, so it will be tough to break the torque, but it should not be that hard. You should be using a 3/8" breaker bar to break the torque, then just a ratchet.
Here are the instructions on servicing: http://iihs.net/fsm/?dir=289&viewfil...%20Filling.pdf
AutoXRacer is offline
Old 02-12-2014, 06:31 AM
  #133
OutlawFirebird
OutlawFirebird's Avatar
Just switched fluid a few days ago. I put rp ATF instead of Synchromax. Feels smother compared to the stock motor craft. First tyranny fluid change at about 32k. I used a pump my dad had in his tool box. Worked really well a few Pumps on each bottle and it was done. I'll snap a picture of it sometime. He helped which made it easier. Also used a lift to do it. Good tread lots of info here.
OutlawFirebird is offline
Old 06-17-2014, 12:36 PM
  #134
pairof11s
pairof11s's Avatar
newbe here, i got a 2011 gt, what trans does it have and does it have the same fill and drain as some of these pic's show?
thanks
pairof11s is offline
Old 08-21-2014, 08:22 PM
  #135
Ponyboy72
Ponyboy72's Avatar
Did you take out the driveshaft in order to gain access to the fill plug? The picture shows what looks to me like the tailshaft yoke bolt up plate...?
Be awesome if you can get back to me asap...latest mod will be this gearbox fluid change asap!
Ponyboy72 is offline
Old 08-22-2014, 06:18 AM
  #136
OutlawFirebird
I did not have to remove my driveshaft when doing my 07gt. I used a pump, to pump the oil in. That's what some use or some run a hose up through the shifter into the cab. I used one like this. http://www.amazon.com/gp/aw/d/B0043YIFGU?cache=779525f80eaa1abcb9a3114b3444b3dd& pi=SY200_QL40&qid=1408706336&sr=1-2#ref=mp_s_a_1_2
Old 02-27-2015, 05:51 PM
  #137
66and06stangs
66and06stangs's Avatar
I've seen several people ask, and if someone answered, I missed it in 14 pages... Are these procedures good for an 06 with a 4.0Liter? I have the std 5 speed, I believe it is the T5. I'm leaning towards the RP (amazon appears to have a sale on it).
A) are these procedures good for a 5 speed in a 4.0?
B) I think RP Syncrhomax is not a bad choice... is it?
Thanks!
66and06stangs is offline
Old 03-17-2015, 11:47 PM
  #138
Pbreakall
Pbreakall's Avatar
Thanks for the awesome post!!!
I followed these instructions yesterday, it was very simple. I was able to use a car lift, and just used a pump to fill up the transmission once it was drained. I used 3QTS of Mobil 1 ATF fluid.
Pbreakall is offline
Old 03-25-2015, 02:45 PM
  #139
66and06stangs
I'm still looking to do my 2006 4.0 liter. I'm looking at RP Synchromax. Good? Not good? Going once, going twice....
Old 03-29-2015, 07:57 AM
  #140
CKurello
CKurello's Avatar
Probably should do this for mine. 80k miles and I don't know if the previous owners ever changed it....and now it's supercharge O.o stock clutch be like no massa, please don't beat me no more
CKurello is offline
Quick Reply: A How To: changing manual transmission fluid
