A How To: changing manual transmission fluid
RE: A How To: changing manual transmission fluid
ORIGINAL: kcmarti
I do not believe I have ever change the tranny fluid on any of my manual transmission vehicles. Is this required? When/what mileage is recommended for the change?
ORIGINAL: kcmarti
ORIGINAL: kcmarti
Hey Moose,
Sorry I didn't read the entire post, but did you finish? I am curious to see how everything works out. I ordered the Mcleod RST today, and 4.10s, thinking about a spyder shaft. The clutch won't ship until 5-9 which sucks. But once it is here the new mods will be prothane mounts, 4.10's, clutch and maybe a spyder shaft. Do you know anyone wanting a cheap Spec'sII + aluminum flywheel? It just needs a new facing $70.00 from specs. I am think 75.00 + shipping for the flywheel.
ORIGINAL: sactown
Hey Moose,
Hey Moose,
I swear my clutch pedal feels lighter than stock, but it could be because I haven't driven the car in a few days. I might still have some air in it as well. Atleast the car doesn't roll when in gear and I rev it. I think I also had an exhaust leak at the header/H pipe connection which i fixed. I figure if I eventually take the whole car apart and put it back together, it just might be perfect when I'm done.
ORIGINAL: acdc163
Hey Moose, I saw them picking on you in the street/strip section, whats up with that?
#20
I have an '05 V6 Mustang (manual). I was having significant issues shifting into gear. Two Ford dealers told me I needed a new clutch (even though it wasn't slipping). I installed Royal Purple MT Fluid a week ago and the difference is night and day. The transmission is now really smooth and I hardly have any issues getting into gears. The majority of the time I have no issues getting into gears.
The car has 35,000 miles on it. The trans fluid that came out was dark brown, sort of like a Guinness or dark coffee color. So, I'd say the fluid should probably be replaced every 30,000 miles at least. And I'd highly recommend Royal Purple. A friend has an E36 ('98) M3 and he put RP in at the same time. His fluid wasn't in bad shape and the difference in shifting was still noticeable.
Mostly, I'd like to thank Moose for the tube recommendation. I can't imagine how much time that saved us.
Any suggestions for changing the hydraulic fluid for the clutch?
-Ryan
-Ryan
