Old 10-12-2015, 02:06 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brake Guides
Print Wikipost
stock brake rotor size?
Old 04-23-2008, 02:50 PM
onederful100
onederful100's Avatar
Default stock brake rotor size?
what are the stock brake rotor size for front and back? are they 12" and 11"?
onederful100 is offline
Old 04-23-2008, 03:01 PM
cartel
cartel's Avatar
Default RE: stock brake rotor size?
12.4 Inch Front and 11.8 Inch rear
cartel is offline
Old 04-23-2008, 03:35 PM
onederful100
ORIGINAL: cartel
[sm=thanx.gif]
Old 04-23-2008, 04:22 PM
ThumperMX113
ThumperMX113's Avatar
Is that deal still available for those slotted/drilled rotors for $200? Does anyone know?
ThumperMX113 is offline
Old 04-23-2008, 04:46 PM
cartel
cartel's Avatar
ThumperMX113 becareful what you buy........I recommend you guys to buy something coated.....I had bought some drilled and slotted rotors on ebay, lmao,,,hahah. trying to same money....They where so pretty, when i got them...I painted the middle and side vents using Duplicolor's ceramic black....I was like wow, this is ghonna be hot....I Installed them. And guess what after a few days? I washed the car, and them suckers looked like I painted them brown....It was filled with rust. No one cant say they dont learn from there mistakes...good thing I only payed $200 for them...So becareful Bud.
[sm=signs003.gif]
[IMG]local://upfiles/71829/045AFC77DFAA4D21B14D20E4F9C441E2.jpg[/IMG]
cartel is offline
Old 04-23-2008, 05:07 PM
ThumperMX113
Well a LOT of people have bought them and have been happy with them. It was a group buy or a big discount.
Old 04-23-2008, 05:10 PM
derekdatank
derekdatank's Avatar
of topic but are the stock breaks any good i mean they are good for road use but how about like on the track and stuff?
derekdatank is offline
Old 04-24-2008, 11:57 AM
Argonaut
Argonaut's Avatar
ORIGINAL: derekdatank
The answer to this question really depends on the Track you are on and your driving style. But generally the recommendation is Stock rotors and Calipers are fine for track use. Pads and brake fluid need to be upgraded at a minimum to prevent/minimize brake fad.
Argonaut is offline
Old 04-24-2008, 12:18 PM
MikeD916
MikeD916's Avatar
Do you know if the stock calipers and brakes are fine when you put bigger rims and tires on? Going from 17x8's to 18x9 and 18x10 with 305's in the back. Dont want the brakes to fail.
MikeD916 is offline
Old 04-24-2008, 01:45 PM
Argonaut
Argonaut's Avatar
ORIGINAL: MikeD916
Yes, the stock rotors and calipers will be fine. The brakes will not "fail", that would be extremly rare regardless of tire size, etc. The stock brakes may "fade" (spongy feel, reduced stopping power) with extended heavy use and little cooling. Depending on driving style you may want to upgrade your pads to something like Hawk HPS. If you are on a road track, upgrade your fluid.
Argonaut is offline
Quick Reply: stock brake rotor size?
