do stangs have rev limiters?
Old 04-19-2005, 11:35 PM
spederman
spederman's Avatar
Default do stangs have rev limiters?
I am not used to my new 02 with 3:55 gears (came with it) and 1st gear wraps up really quick. Every so often I'll try to go be ear to shift and when I do look down the tach is buried in the red (7K rpm). I have done this only a few times but hope I didnt screw anything up. Does the Mustang have a rev limiter that it will bounce off if I hit it or will it just blow the engine? My G35 I sold had a rev limiter so I knew that it would catch the RPM's if I shifted too late.
spederman is offline
Old 04-19-2005, 11:42 PM
DuckyGt
DuckyGt's Avatar
Default RE: do stangs have rev limiters?
im pretty sure your stang has a rev limiter because on my predator it has an option to change it not really my field of expertiece tho
DuckyGt is offline
Old 04-19-2005, 11:46 PM
orang04gt
orang04gt's Avatar
your limiter should be set at 6200. unless it been changed with a programmer or chip.
orang04gt is offline
Old 04-20-2005, 12:47 AM
the07sniper
the07sniper's Avatar
yea, it does. im not sure about gt, but i have a99 cobra and ive hoit the rev limited before when i wasnt paying close attention.
the07sniper is offline
Old 04-20-2005, 03:29 AM
Mike02GT
Mike02GT's Avatar
Yes i have a 02 gt... the rev limiter is set at 6050rpm,stock, but i have a predater and i reset mine to 6200rpm...
Mike02GT is offline
Old 04-20-2005, 04:45 AM
LIVIN_LEGEND
LIVIN_LEGEND's Avatar
6050 with predator i set mine at 6150.......... its good to have. ive hit it a few times in the heat of battle
LIVIN_LEGEND is offline
Old 04-20-2005, 08:26 PM
racer02GTstang
racer02GTstang's Avatar
i dont have a rev limiter.... a couple times ive missed shifts powershiftin cause the shifter wouldnt go in and i hit 7500 rpms. that scares the sh*t out of me when it does that. i have a superchips programmer so that could be why. does anyone know how i can set my rev lmiter to like 6500 or so if i miss a shift. i dont want to blow the motor.
racer02GTstang is offline
Old 04-20-2005, 08:33 PM
MikeHawke
Retired MF Moderator
MikeHawke's Avatar
ORIGINAL: racer02GTstang
yeah, 7,500 is pretty high for a 2V LOL. You better check your manual for the programmer or check the website.
I don't know why anyone would want to raise the rev limit.....these engines stop producing any reasonable amount of power at 6,000 anyway. May as well shift back into the powerband.
I have the predator too and left the rev limiter alone. Kicked the traction control to the curb though
MikeHawke is offline
Old 04-20-2005, 08:54 PM
98UAGT
98UAGT's Avatar
Yeah, revving past 6200 is useless, cause shifting at this point will put you back into the powerband. Otherwise all you are doing after 6200 is beating the crap out of your motor, you won't be making much power unless you have some radical cams.
98UAGT is offline
Old 04-21-2005, 01:18 PM
SweetStang04GT
SweetStang04GT's Avatar
Racer02, i think i had the same problem as you. I have superchip as well and i opened my baby up on the high way and when i came out of first and tried nailing second it just grinded. So at first i am like, damn i am getting a little rust behind the wheel, so i tried again.... Grinded again... I had to adjust the stop screw in the shifter. I hope that is what was wrong because all bottom gears were gone and i thought i blew the tranny. I was at about 6100 when i shifted and this happened.
Starting to wonder if it is the chip now that i read your post....
SweetStang04GT is offline
Quick Reply: do stangs have rev limiters?
