Hood paint bubble (rust) TSB?
Old 04-29-2008, 06:43 PM
  #21
pascal
S197 Section Modder-ator
pascal's Avatar
Default RE: Hood paint bubble (rust) TSB?
It's called Corrosion.
Aluminum isdefinitly prone to it.
In fact, salt water does a nasty number on Aluminum.
In our case with our cars/trucks, it's a bad prep from Ford. Or a contaminant in the etching primer, rather.
pascal is offline
Old 04-30-2008, 03:15 PM
  #22
mcgyvertech
mcgyvertech's Avatar
This same issue occurred with my Stang, the dealer replaced the entire hood and repainted it to better than OEM specifications. Good Luck!
mcgyvertech is offline
Old 04-30-2008, 03:53 PM
  #23
Kara
Kara's Avatar
I wish they would repaint mine! i have rock chips blah
Kara is offline
Old 04-30-2008, 03:59 PM
  #24
Kara
Kara's Avatar
I just looked at mine and didnt see any bubbling. Just some chips right there[:@]
Kara is offline
Old 04-30-2008, 05:27 PM
  #25
americaniron
americaniron's Avatar
ORIGINAL: BeeStang
I'm confused, I thought the hood was aluminum. Aluminum doesn't rust!
Also, someone said something about a recall, recalls are for NTSB saftey issues, not stuff like paint and rust.TSB (Technical Service Bulletin) as one poster said, it's for known problems and what the fix is, not a guarantee that Ford will fix it for free, unless it occurs under warranty.
I agee that regardless, the dealer should fix it,due tobad factory prep before the car was painted (I'm thinking oil, or some kind of solvent on the hood).
One final thing, the 6/60 rust warranty only applies if the metal is rusted through, it doesn't cover surface rust, "been there experienced that" LOL.
It's true that almost every recall is for saftey issues, there have been recalls for non saftey problems. The 99 Cobra is an example.The Feds ordered it recalled by court order because it did not meet the advertized H P output. Owners filed a lawsuit and won.Ford had to rework the intake, and exhaust so that it would make the320 hp itclaimed to have.That was for all owners of that year. Even so this hood corrosion problem will never make that kind of status.
americaniron is offline
Old 04-30-2008, 05:29 PM
  #26
Qusus
Qusus's Avatar
Does anyone have a picture of what this hood corrosion looks like? Or a link to a picture. I tried to google it and use the MF search function but haven't found anything.
Qusus is offline
Old 04-30-2008, 05:40 PM
  #27
Kara
Kara's Avatar
I agree we needs pics of it
Kara is offline
Old 05-01-2008, 09:40 AM
  #28
jet21
jet21's Avatar
ORIGINAL: antipeterleague
i found a few really small bubbles on the inside of my 08 hood!!! (the 08s are supposed to NOT have this happen)
i'm taking it in later this week.
Where exactly are these bubbles? Do you have a pic? I have a 2008 and will check on mine.
jet21 is offline
Old 05-01-2008, 10:24 AM
  #29
Daniel60
Daniel60's Avatar
Need pictures.
Daniel60 is offline
Old 05-01-2008, 10:31 AM
  #30
richmod
richmod's Avatar
Go to these threads for pictures:
http://forums.bradbarnett.net/showth...021&page=3
http://www.allfordmustangs.com/forum...-bubbling.html
It can vary from just a few bubbles under the hood lip to severe bubbling on the outside of the hood.
richmod is offline
Quick Reply: Hood paint bubble (rust) TSB?
