will newer rims fit?
Old 05-02-2008, 12:47 AM
Vikefan88
Vikefan88's Avatar
Default will newer rims fit?
will the bullit rims and tires on newer stangs fit for older mustangs 5 bolt patterns
Vikefan88 is offline
Old 05-02-2008, 12:50 AM
FuzzyDiceRule
FuzzyDiceRule's Avatar
Default RE: will newer rims fit?
should if you get the right spacing, IMHO, the AM Racing Torq Thrusts look better on the old ones, Bullitts are more for the new ones
FuzzyDiceRule is offline
Old 05-02-2008, 12:55 AM
Vikefan88
Vikefan88's Avatar
i really dont much about rims and tires... so if i get some of the stock rims and tires that come from the new gt models they'll fit? where do i get the spacer and how will it work?
Old 05-02-2008, 01:08 AM
SalikDDD
SalikDDD's Avatar
i have newer style bullitts on my car, but i hate em, too big, too heavy and too bling :|
SalikDDD is offline
Old 05-02-2008, 01:14 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
if you use the 01-04 bullits you will need a 1 inch adapter in the front and a 1/2 spacer in the rear. if you do the 05-08 bullits you will need 1.1/2 inch adapter int ehfront and 1 inch in the rear
rmodel65 is offline
Old 05-02-2008, 01:17 AM
Vikefan88
Vikefan88's Avatar
and those spacers? where do i get em? there like a plate right?
Old 05-02-2008, 01:25 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
i bought mine from www.dallasmustang.com
rmodel65 is offline
Old 05-02-2008, 01:36 AM
Vikefan88
Vikefan88's Avatar
wat will happen if i mount the new rims on the older car with out a spacer?
Old 05-02-2008, 02:33 AM
MonsterB
MonsterB's Avatar
im not sure but i think your car will explode, or turn into a chevy!
MonsterB is offline
Old 05-02-2008, 03:31 AM
66JameStang
66JameStang's Avatar
heel chart that was put together by dodgestang is amazing and will help you out...
http://www.dodgestang.com/cgi-bin/pr...ts%201965-1973
go to the wheel chart section and look in awe!
66JameStang is offline
Quick Reply: will newer rims fit?
