87-93 Under Dash Wiring Harness
Old 05-07-2008, 05:42 PM
87Stallion
87Stallion's Avatar
Default 87-93 Under Dash Wiring Harness
Are the under dash wiring harnesses all the same for fox bodys? Im wondering if a inside harness from a 4-cyl will work in my GT and does it have to be a 87 like mine?
87Stallion is offline
Old 05-07-2008, 06:38 PM
dave1170
dave1170's Avatar
Default RE: 87-93 Under Dash Wiring Harness
Some people say they are the same. I've done a few swaps and every time the 4 banger harness would screw up the gauges. When I changed them over with a 5.0 harness everything worked fine. So, IMO, the 4 banger harness will cause problems. The dash harness from a 87-93 5.0 will work fine for you, they are all the same. The engine harnesses were different on certain years. Hope this helped!
dave1170 is offline
Old 05-07-2008, 06:54 PM
87Stallion
87Stallion's Avatar
Was that because you had 4 banger guages? Just wondering if it would work on a 5.0 with original 5.0 guages. My thinking is the harness itself should be the same. Just wanted to ask before I try it. I have looked at several 4-cyl harnesses and I can't find any differences but that doesn't mean that there isn't.
The previous owner butchered the inside harness on my car.
Old 05-07-2008, 07:29 PM
dave1170
dave1170's Avatar
That was with the 5.0 gauges installed.
dave1170 is offline
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
Quick Reply: 87-93 Under Dash Wiring Harness
